Author Topic: 1970 Cuda resurrection  (Read 119240 times)
Offline HP_Cuda
  • Mopar or No Car!
Re: 1970 Cuda resurrection
« Reply #225 on: March 14, 2014 - 02:58:16 PM »
Thanks Tom!
All I can say about wiring at least from a dash perspective is to check that everything works and is in it's proper location when you put up the dash. It's not that you can't get to it afterwards but it sure is a real pain since I'm tall.
I am actually looking forward to wiring the engine bay as I enjoy that and the trunk was a snap. I went back and looked and I didn't post anything about the trunk wiring harness but it was pretty dang easy. The only troubling part was getting the lights in the marker light housings as it's kinda a tight fit but doable.
I'll be posting updates soon.
B
That's great news  :jumping:
can't wait for the next chapter.  :popcorn:
I'm getting started on my wiring so I will be focused.  :thumbsup:
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« Reply #226 on: March 14, 2014 - 03:14:10 PM »
The issue I had with the trunk was that with the new paint, I couldn't get a good ground to the body for the lights to work. I ended up making a ground wire for each of the marker lights and bolted them to the tail lights.
For the dash, I made the mistaken assumption that since everything worked before I took it apart (over a decade prior), that it would work after putting it back together. The real issue was that the dash dimmer switch was corroded and I had no dash lights. Surprisingly it was an easy fix. I thought I might have had to buy a new one. Was able to clean the corrosion in ~5min with some household chemicals.
Offline quapman
    • Auto-Grip on Facebook
« Reply #227 on: March 15, 2014 - 11:05:47 PM »
VERY nice work. I hope mine goes as well once I'm in gear. I'm starting with a primed shell that needs final blocking and about 37 zillion other little things done before I even think about color.
FYI: Limelite and Sublime are the same color, just different names.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #228 on: March 17, 2014 - 03:41:21 PM »
Well I can now have a sigh of relief as the new windshield is in and put in correctly.
I've got pretty much everything hooked up to every component of the dash so I can now work on moving into wiring the engine bay.
I'm sure glad this is done!  :cheers:
Offline Plum6Pak
  • Plum6Pak
« Reply #229 on: March 17, 2014 - 04:24:27 PM »
 :wow: That totally amazes me, nice work! What a change! Keep up the good work and pictures too!
Offline CudamanTom
« Reply #230 on: March 17, 2014 - 04:33:41 PM »
Oh man that is lookin good. Love the interior shot.  :ylsuper:
Very nice lookin dash setup.  :2thumbs:
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #231 on: March 19, 2014 - 07:40:55 AM »
Getting closer  :bigsmile:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #232 on: March 26, 2014 - 12:26:27 PM »
Got the ebrake cable in the front along with the assembly. Funny how you are looking for an example on cable routing and it's the hardest one to find.
Glad I got it figured out.
Offline CudamanTom
« Reply #233 on: March 26, 2014 - 04:56:02 PM »
Hey Buddy,
Looks like we both are busy with Inline Tube.
Both fuel lines.
Just got it in this afternoon.  :bigsmile:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #234 on: March 26, 2014 - 06:42:19 PM »
Heh yep Inline all the way, I'm just about to go hook up the rear cables and finish this baby off so I can put in the rear discs!
 :2thumbs:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #235 on: April 01, 2014 - 10:55:19 PM »
Took a break from wiring to do something a bit more esthetically pleasing.
Finally got the console in and put the CF grips on the pistol grip!
 :ylsuper:
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #236 on: April 01, 2014 - 11:42:38 PM »
Where do I get all the carbon fiber?
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline CudamanTom
« Reply #237 on: April 02, 2014 - 06:57:46 AM »
 :2thumbs:
Very nice looking!!!
Offline anlauto
« Reply #238 on: April 02, 2014 - 07:27:01 AM »
Before you bolt the console down, paint the front bracket black :2cents: That little bit of green showing will drive you nuts :o
Offline HP_Cuda
  • Mopar or No Car!
« Reply #239 on: April 03, 2014 - 11:37:00 PM »
Good Eye Alan.
It's fairly easy to remedy.
