Remember back in the day when everyone was putting Accel Super coils on their cars? Well, the dirty little secret that no one told anyone - was that your factory stock electronic ignition is just fine. You only need to upgrade if you are flat out drag racing. The electrical system is only going to use what it does. IE, the system is only going to use what volts it needs to jump the spark plug gap and travel through the wires. If you gap your plugs at 1/4 inch", then the coil will have to build much more voltage to overcome that gap. If you gap your plugs at 1/8", less voltage will be needed to overcome that gap. People that say that they can feel a difference are usually just saying that to cover up the fact that they spent hundreds of dollars on a part that will NEVER ever see race conditions, and NEVER out perform the factory ignition- but they have to justify the hundreds of dollars spent by saying "oh - it feels better, or oh it idles better, or oh it starts better" BULL HOCKEY! Electricity takes the path of least resistanse. If you gap your plugs way out their to get a hotter spark, the electricity may just find another path to ground through your wires or boots. THIS IS BASIC ELECTRICITY! NO MSD or accel super coil or any of that, Jacobs, it's all BS to get your money, show me a true dyno test where any of these systems have ever made a difference. PROVE ME WRONG! The factory stock set up is more than you will ever need. Any one else that says different is a liar or doesn't understand basic laws of electricity. ANYONE. Unless you are racing in a very high rpm enviroment all the time, the aftermarket systems are not worth the money as far as you can spit. GM HEI is far superior to Mopar, But, Mopar electronic is just fine. Just because a coil says it can produce 50,000 volts, doesn't mean that it does that! The volts only are used as your engine needs them, and I bet you never even see over 10,000 volts at Wide OPEN Throttle! SAVE YOUR MONEY! Research this if you don't believe me. And for all you people that say you can see/feel a difference.... PROVE IT! There is NO difference! except a lighter wallet and bragging rights. People that brag different are dumba$$$es and want to cover their butts by saying they can feel a difference. They are merely saving face. Factory is fine. Unless you are spinning 7500 rpm and higher.
