another cheap disc brake conversion
Author Topic: another cheap disc brake conversion  (Read 1185 times)
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
« on: February 04, 2005 - 11:37:34 AM »
THEY USE YOUR EXISTING a body drum brake spindles but you remove the drum from the hub, reuse the hub use the custom brackets and get some S10 4wd rotors( there the hat rotor style)re drill them with the template supplied,use S10 2wd calipers and pads, and caprice brake hoses.simple and cheap! parts only cost 90.00 for the calipers, pads,and rotors.
http://www.scarebird.com/
here are pictures of the b body set up
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=4524002666&category=34199&sspagename=STORE%3APROMOBOX%3AGENERIC
« Last Edit: February 04, 2005 - 12:35:35 PM by OUTLAW »
Offline 71'cuda340
  • Mopar OR slow car!
Re: another cheap disc brake conversion
« Reply #1 on: February 05, 2005 - 12:43:18 AM »
Have you tried this conversion?  Or has any one else on this board done it?  It sounds like a good cheap way to do it.   :dontknow:
I really need to change mine to disc and any help would be great.
« Last Edit: February 05, 2005 - 12:51:21 AM by 71'cuda340 »
Offline OUTLAW
« Reply #2 on: February 05, 2005 - 01:57:15 AM »
One of the Mopar magazines is suppose to have a article on it this month but as usual i don't get mine until the end of the month (some subscription  huh!)
