Dr Diff is the Man!
Author Topic: Dr Diff is the Man!  (Read 14157 times)
Re: Dr Diff is the Man!
« Reply #30 on: May 09, 2012 - 08:45:27 PM »
I would.....but mine is only a lowley 7 1/4   :roflsmiley:
Wow! I didn't think they ever put those in Barracuda's, or Challengers. Slant six cars?  :clueless:
« Reply #31 on: May 09, 2012 - 09:58:59 PM »
That's what mine had in it when I got my car ( mine was a /6 car). The shippers were nice enough to scatter it all over the ground doing burnouts with my car. The driveshaft too. Funny 440 and a 7 1/4 don't mix...who knew? :lol:
« Reply #32 on: May 09, 2012 - 10:04:33 PM »
Someone had the know-how to put in a 440, but not change the rear end eh?
« Reply #33 on: May 09, 2012 - 10:07:39 PM »
 Ya I guess? I was planning on changing it anyhow so not a real big deal. I just took off the drum brakes and tossed the rest in the scrap yard, leaf springs and all. The cover had a few extra " lumps " in it :lol:
Offline 67vertman
  • Member since 9-23-2005
« Reply #34 on: June 10, 2012 - 04:29:40 PM »
Alright, I finished installing the Dana 60!  :woohoo:
The installation went pretty smooth with only a couple of minor hiccups. One was my bending and flaring of the brake lines, I made one line about a ¼ inch to short, and when I tightened the line it pulled the flair into the fitting and started leaking, so I had to re-bend and flair a new line.  The other was the emergency brake lines, I went with the Doctor Diff econ disk brakes, and the line did not come with directions, so routing them was a pain, as was taking of the old lines, lots of soaking the bolts with penetrating oil, cleaning and chasing the threads before removing them and they still fought me the whole way.
Other than that, it was a lot off cleaning and painting the parts. Looks good and works even better.
What  a difference the 4:10 gears make.   I got my first “chirp” in second gear!
« Reply #35 on: June 10, 2012 - 08:15:48 PM »
 :2thumbs:
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #36 on: June 11, 2012 - 01:43:27 AM »
Nothing beats a Dana 60 for brute strength. That's on my wishlist for my Challenger. I have a 7 1/4 rear end in my '68 Barracuda. It used to have a slant-6. It's one tough rear end as the car now has a mildly built 360 with an A-904 automatic tranny and I have thrashed the mess out of that rear end (burn-outs/donuts galore) with no problems. It was rebuilt before the 8 cylinder was installed, but never upgraded to a bigger rear end. Maybe one day it will self-grenade, but it's proving to be Mopar tough as it's been pounded for about ten years now with no problems!!  :2thumbs:
        Matt B.
Matt
Offline TROUBLE987
Dr Diff is the Man!
« Reply #37 on: August 04, 2012 - 10:11:17 PM »
My rear ended up costing a couple hundred more than building a 8.75 from scratch. I figured the wow factor was worth it. Since my convert had the puny 7.5 rear I didn't have anything to start with. Dr. Diff drop shipped the housing to me from Strange engineering so I could mock up the panhard bar, sway bar, and three link mounts. I shipped the bare Strange housing after I mocked it up to Cass (Dr Diff), he built the axles, finished the welding, bent the brake lines, assembled the brakes, installed the gears, and powdercoated the whole shebang. Awesome work.
Couple of questions..what kind of brakes and how did you mock up the rear..I have no motor and trans in mine and I'm wanting to have my brackets welded on before powder coating also..I'm installing a ride tech rear suspension and want to weld all the brackets on..I guess my question is how can I make sure I get the pinion right before I weld it up..I'm also getting my Dana from cass too..thx
Offline 67vertman
« Reply #38 on: August 05, 2012 - 01:34:20 PM »
I got my brakes from him as well.  He uses the Cordoba 10.75 disk brakes.  The come with bracket that you install.  As for the pinion snubber in mounts on the rear end, if you are talking about the pinion plate on the body, I’m not sure how you fit it..
« Reply #39 on: March 27, 2013 - 08:41:17 PM »
I just received mine the other day.
Offline 67vertman
« Reply #40 on: March 27, 2013 - 11:08:37 PM »
 :woohoo:  :bananasmi
you are going to love it Mike!   :2thumbs:
« Reply #41 on: March 28, 2013 - 02:55:09 AM »
Nice new shiny parts Mike! :clapping: Did you get the tru trac set up?
« Reply #42 on: March 28, 2013 - 10:06:05 AM »
 :grinyes: and Powder coated.  :bigsmile:
« Reply #43 on: March 28, 2013 - 05:52:21 PM »
Nice your going to love it! I'm very impressed on how straight the car goes even with both wheels up in smoke!  :aarg: :clapping:
