Author Topic: Any high zinc oils at the generic auto stores? Auto zone/napa/car quest?  (Read 15958 times)
Offline The4ork
Looking for something I can find locally
Offline Katfish
  • 70 Challenger
You can get Lucas at Advanced Auto, $15 is good for 3-4 oil changes.
Good timing for this post.  I'll be needing oil very soon.  I've heard that there's a diesel oil that has a high zinc content.  Anyone know what that is?  I've also heard that the zinc additives aren't as good as the oil that already has the zinc in it....just what I've read...don't know if there is any truth behind it.
Offline wiging19
Appreciate your sharing.  :bigsmile:
Offline JH27N0B
I've been using Shell 15-40 Rotella diesel motor oil in one of my Challengers for several years now. It is available everywhere and cheap.  But I've heard the zinc content is being cut even in diesel motor oils so I'm not sure if that is still a good choice.
I use Valvoline VR-1 Racing oil in my V code.  It is advertised as having a high zinc content.  It is also widely available.
Royal Purple is supposed to be pretty good, and not hard to find at Auto parts stores.  It is pricey though, a few weeks ago I saw it as O'Reillys and it was over $8 a quart! :22yikes:
the Rotella oil meet sm specs so no it doesn't have enough zinc anymore
 Check out Z Alt oils as well
Offline challengermaniac
For the initial 500 break in miles following a motor rebuild, my builder has always recommended straight 30 weigth motor oil (non detergent) and thereafter I am planning to go with an oil such as Brad Penn with a Zinc additive.
Charlie
70 Challenger 340/4 Purple
70 Challenger T/A Red
Edmonds, WA
Offline RCCDrew
« Reply #7 on: April 02, 2012 - 04:56:06 AM »
I use the VR1 also.
Offline TinCuda
    • 'Cuda
I use the VR1 also.
 :iagree: I use VR-1
I get it at Auto Zone.
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
I'm also using the VR-1. I see comp cams has high zinc oil now too? Although I don't know the zinc content?
Offline GoodysGotaCuda
Re: Any high zinc oils at the generic auto stores? Auto zone/napa/car quest?
« Reply #10 on: April 02, 2012 - 08:53:04 AM »
Last time I checked, which was about a year ago, Mobil 1 15w-50 synthetic (walmart 5qt jug) had a pretty high zinc content.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline EB3-GranCoupe
  • BP23 U0B
Offline vinb
« Reply #12 on: April 02, 2012 - 01:56:18 PM »
Mobil  Del-vac 1300
Motorcraft  Super duty
Chevon  Delo
all 15-40w and are CI-4 PLUS.
Offline voodoocld
« Reply #13 on: April 04, 2012 - 11:10:52 AM »
Why would running a non detergent be good right after a an engine rebuild? I would think that after a rebuild you would especially want to capture and suspend the small metal particles and send them to the filter. If you had a non detergent, i would think the particles would just be floating throughout the engine with no guarantee that when you change the oil and filter your getting them all out of the engine.
Only time to use non detergent would be in a lathe or gear box, where you want the particles to fall to the bottom so there not being pushed through the bearings. Seems like there would be far to many places for the particles to get caught an engine (lifter valley, heads, etc..).
« Last Edit: April 04, 2012 - 11:13:33 AM by voodoocld »
Offline The4ork
« Reply #14 on: April 07, 2012 - 05:08:40 AM »
same, this is what ive always used with newly rebuilt engines, and using a high zinc assembly lube
