Author Topic: what goes between tank straps and the tank itself?  (Read 1102 times)
Offline black71
  • eph 6:12
« on: April 02, 2012 - 01:44:22 PM »
Ha there was old carpet in there before..do I need rubber or????
Offline 06Daytona
Re: what goes between tank straps and the tank itself?
« Reply #1 on: April 02, 2012 - 02:29:28 PM »
I usually use strips of old tire tube. I put them in wider than necessary and then trim with a razor blade so they're pretty much invisible
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
Offline GranCuda1970
« Reply #2 on: April 02, 2012 - 02:51:44 PM »
I heard black roofing roll works great!!
Offline Gumby
« Reply #3 on: April 02, 2012 - 03:15:54 PM »
If you cut with a razor, be careful not to score the tank or you will invite rust. Tarpaper (a thick heavy felt type roofing material) is what most use. You could probably find a scrap at your local lumber yard for free.
{oo/-------\oo} In '69 I was twenty-one and I called the road my own. I don't know when that road turned into the road I'm on. Jackson Browne
Offline swede-cuda
« Reply #4 on: April 02, 2012 - 03:18:17 PM »
                                                        :wave:im not sure,but i dont think anything goes there. i have the roof stuff on the upside against the trunk..  :bigsmile:
« Reply #5 on: April 02, 2012 - 03:22:54 PM »
Nothing was originally there.  Some people like adding a little roofing felt to that area.
Offline Gumby
« Reply #6 on: April 02, 2012 - 03:55:27 PM »
Sometimes adding stuff where the factory didn't is a bad idea. Sometimes the roofing material or whatever can trap moisture and pebbles and actually cause rust. If you are adding a new gas tank and are really worried about it, I would just buy some 3M spray undercoating and give the tank a coat of that before installing. Anything that you might "layer" will hold moisture.
« Reply #7 on: April 02, 2012 - 09:28:42 PM »
there was a pad between the body & tank but nothing between the straps & tank
Offline usraptr
« Reply #8 on: April 02, 2012 - 10:59:41 PM »
 :iagree:   :2thumbs:
(Edited 8-1-17)
« Reply #9 on: April 02, 2012 - 11:35:04 PM »
Offline LAA66
« Reply #10 on: April 03, 2012 - 11:14:28 PM »
 Some roofing paper is abrasive so keep that in mind. I used a plastic shower mat on the trunkside and small rubber pads on the strap where the bends occur.  Also sprayed the tank clear polyurethane prior too. Yeah kinda overkill. ::)
