Author Topic: Tach Question??  (Read 1873 times)
Offline woody9512
  • 71 Billboard Cuda, Pistol Grip 4-speed.
Tach Question??
« on: April 02, 2012 - 11:01:56 PM »
Where does the wire from tach actually attach to on the engine itself? Want to see if it maybe came off?   71 Cuda 340.
Thanks
Tim
Offline highberg
Re: Tach Question??
« Reply #1 on: April 02, 2012 - 11:30:46 PM »
Negative side of the ignition coil
Classic Restorations
1973 Cuda 496 Stroker NOS
1971 440+6 4 Speed Roadrunner
1961 Shortbox Fleetside D100
1970 Dodge Dude 383 Auto
2009 SRT8 Challenger 6 Speed
Offline woody9512
Re: Tach Question??
« Reply #2 on: April 02, 2012 - 11:32:13 PM »
Ok............Thanks.
Offline woody9512
Re: Tach Question??
« Reply #3 on: April 03, 2012 - 12:42:14 PM »
Is the positive and negative sides of the coil itself actually marked with a + and - like a battery?? If not
how do I know which is which??
I looked and my Cuda 340 has wires attached to both bolts on the coil? Which one is the one specific for the tach and what are the others? I took a look and appears to be 3 wires in total attached to the coil itself?
Does anyone maybe have a picture of the correct attachment for the wires?
Thanks as Always!
"Tim?
Offline TinCuda
    • 'Cuda
Re: Tach Question??
« Reply #4 on: April 03, 2012 - 02:14:01 PM »
Your coil is probably marked with raised symbols or paint.  On my coil the pos has a blue wire and the negative has one yellow wire with a black stripe and one gray wire with a black stripe.  Typically a green wire goes to the neg side of the coil from your tach.
« Last Edit: April 03, 2012 - 02:18:58 PM by TinCuda »
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
Re: Tach Question??
« Reply #5 on: April 03, 2012 - 03:31:59 PM »
The coil should be marked, but you might have to remove the wires to see it. If you are using the Rally gauge harness, the tach wire is gray.
Offline woody9512
Re: Tach Question??
« Reply #6 on: April 03, 2012 - 08:00:31 PM »
It has a rally dash / tach so I will check the wires.
Thanks
"Tim"
