Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Proportional valve and meter block
« previous
next »
Print
Pages: [
1
Author
Topic: Proportional valve and meter block (Read 8042 times)
300
Jr. Member
69 chevelle,67chevelle , 70 barracuda
on:
April 04, 2012 - 09:36:26 AM »
Hello, Anyone got a diagram of the brake lines from Master C down to prop and meter valve. The 70 Cuda Manual page 5-59 shows it, but not the front side, I know one gets blocked of ( disc conversion on front ) Thanks
Logged
GranCuda1970
Sr. Resident
Rev 20:4. Mat 6:33 John 1:3 Mat 26:41
Re: Proportional valve and meter block
Reply #1 on:
April 04, 2012 - 09:48:53 AM »
This help.
Logged
300
Jr. Member
Reply #2 on:
April 04, 2012 - 10:01:37 AM »
Great Have you got the top port at the front Blocked off?. If so, the one below that is for the rear, going throughout to the Braided one in your pic, I have the same set up, and no fliuld going to rear, had it at inlet, not outlet ?
Logged
GranCuda1970
Sr. Resident
Reply #3 on:
April 04, 2012 - 10:22:01 AM »
yep there is a small bolt blocking it!! Also you need the valve for the drivers side frame rail under the pedals. I will bleed them today after the dash and wiring if I have time today!
I will post a pic in a few mins.
Logged
GranCuda1970
Sr. Resident
Reply #4 on:
April 04, 2012 - 10:27:37 AM »
Here it is!
Logged
300
Jr. Member
Reply #5 on:
April 04, 2012 - 12:00:37 PM »
Thanks for pic, You say there is another valve too on frame rail ? My line from back came right along and perfect fit to Prop valve ?
Logged
GranCuda1970
Sr. Resident
Reply #6 on:
April 04, 2012 - 12:07:06 PM »
Yep it puts a delay on the brakes to prevent unproprtion braking at the rear.
it is also in the 70 service manual for front disk rear drum application on a barracuda stock design. Inline tube breake lines are split this valve.
Last Edit: April 04, 2012 - 12:08:37 PM by GranCuda1970
Logged
tx9aarcuda
Jr. Member
Reply #7 on:
April 09, 2012 - 09:51:33 AM »
I am by no means an expert but I thought I had read some where if your build date was after 1/1/70 you didn't have the valve on the frame rail.
I thought this came from Barry Washington, I will try to look around here or the Hamtramck Registry and see what I can find.
Logged
Greg
68 Coronet R/T Convertible 4 spd
70 AAR Auto
97 Ram 1500
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
