Author Topic: Horn Issues  (Read 686 times)
Offline cv70chall
  • 1970 Challenger
Horn Issues
« on: April 06, 2012 - 08:31:05 AM »
My horns were grounding out at the column, so I took it apart and found that the small insulated ring under the brass contact wheel on the crush can was completely deteriorated. I replaced that with a grommet which seemed to work perfectly. Problem now is- when I put pressure on the top of the steering wheel itself and press down- the horn goes off, so I still have a grounding issue, right?
Is there some insulator or spacer that prevents the crush can from making contact with the steering column where they meet?
Thanks
Offline 74challenger03
Re: Horn Issues
« Reply #1 on: April 06, 2012 - 11:01:00 AM »
there was no insulater between my crush can and steering column,it sounds like your horn contact is still grounding out.
Offline spamtank
Horn Issues
« Reply #2 on: April 06, 2012 - 12:00:41 PM »
I had a similar symptom. I had something put together wrong.  I'll check my notes and photos when I get home.
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Offline swede-cuda
Re: Horn Issues
« Reply #3 on: April 08, 2012 - 12:23:08 PM »
Thanks                                       :banghead: theres no ring(sort of),the deterioated ring you found was probably dried remains of rubber from the hornswitch(brass contact wheel under crush can) the hornswitch should have soft rubber covering both sides of it.when the rubbercover gets old it gets hard and cracks.i found a nos o ebag from another mopar product,just needed a bit longer wire to reach up through the crush can. or maybe there is a way to dip it in something to get it a new insulation? fix it or the horn will honk when you turn the wheel..
