Author Topic: heater box door  (Read 1196 times)
Offline 30below
heater box door
« on: April 06, 2012 - 09:21:36 AM »
Think i installed the defroster/floor heat door in wrong.The lever where the cable attaches swivels front to back and i think it should swing left to right.Can anyone check theirs?Also does that cable that operates this door have a 90 degree bend at one end?and if so at which end?
Re: heater box door
« Reply #1 on: April 06, 2012 - 09:24:55 AM »
PM sent...
Offline usraptr
Re: heater box door
« Reply #2 on: April 06, 2012 - 12:45:31 PM »
Here are some pics of mine after I restored it.  Let me know if you need any more.
(Edited 8-1-17)
Offline usraptr
Re: heater box door
« Reply #3 on: April 06, 2012 - 12:49:02 PM »
Sorry, not sure what happened but it posted the wrong pics.  Let's try again.
(Edited 8-1-17)
Offline 30below
Re: heater box door
« Reply #4 on: April 06, 2012 - 01:02:49 PM »
Thanks for the replys guys and Pms.looks like i have to take it out again[been a couple years].The dash was not in last time,so any tricks to make this easier?That hook in the air plenum looks like fun.
Offline 4Cruizn
  • HEMI FISH
Re: heater box door
« Reply #5 on: April 07, 2012 - 01:40:43 AM »
Wow usraptr . . . That looks great!  You did that yourself?  Very cool . . I just pulled mine out today and need to replace the heater core in the morning.   Maybe next winter . . . I could try to make it look as good as yours.
Offline usraptr
Re: heater box door
« Reply #6 on: April 11, 2012 - 04:51:32 PM »
Thanks, yes I did do it myself.  Cleaned all the metal parts, motor,etc and then sprayed with paint.  Used the foam/gasket kit from Detroit Muscle ( I think that's the right name) and after reassembly sprayed the case with matte clear.
(Edited 8-1-17)
Offline 30below
Re: heater box door
« Reply #7 on: April 18, 2012 - 09:03:38 AM »
Thanks for the help guys.Finally got around to pulling it out.Took about 1 hour to take it out,fix the door and reinstall.A lot easier than i thought
