Author Topic: 8 inch wheels all the way around  (Read 2654 times)
Offline cdstl
« on: April 07, 2012 - 10:33:12 PM »
Does anyone have 8" wheels on all four corners?  If so would you mind posting some pictures along with the tires size?
Thanks
Offline 72bluNblu
Re: 8 inch wheels all the way around
« Reply #1 on: April 08, 2012 - 12:32:44 AM »
Not 8", but I run 17x9" rims on all 4 corners. 5" backspace, 275/40/17 Toyo Proxes 4's all around. What diameter wheel are you looking for?
You should check out the wheel and tire combo thread, should be some more info there. I know there's at least a few people running at least 8" rims on the front, which is really the bigger issue. 8" rims on the back are no problem...
Offline _Russ_
  • Not very family friendly!
  • Chk Chk Boom!
    • Show Me How To Live
« Reply #2 on: April 08, 2012 - 03:55:13 AM »
- 15x8 on all corners.
- 235/60 up front.
- 255/60 out back.
Offline cdstl
« Reply #3 on: April 08, 2012 - 07:35:07 AM »
Nice shots.  I should have given a little more info.  I am thinking about putting 15x8 Rallyes all of the way around on my 72 Cuda.  Russ, did you have any steering problems and would you have any angle shots?  Also what is the backspacing on those Rallys?  Those 17s look good too.
Thanks
« Last Edit: April 08, 2012 - 07:37:02 AM by cdstl »
Offline _Russ_
  • Chk Chk Boom!
« Reply #4 on: April 08, 2012 - 08:50:16 PM »
Zero steering, rubbing or fitment issues.
No idea on the backspacing. They were on the car when I bought it, but I'd put money on them being 4.5" (4 1/2").
Offline cdstl
« Reply #5 on: April 08, 2012 - 09:53:26 PM »
Sweet, thanks for the shots.
« Reply #6 on: April 09, 2012 - 09:15:49 AM »
The car in my avatar is 8" all around. 4.75 back space, 235/60 front and 295/50 rear.
Offline cdstl
« Reply #7 on: April 14, 2012 - 09:16:38 AM »
Could you post a few  pictures of your car too?  I am saving different combinations in a folder so that when I can pull the trigger I will have already decided what I want to do.
Thanks
« Reply #8 on: April 14, 2012 - 09:55:39 AM »
Sure, Here are some of the above combo.
Offline cdstl
« Reply #9 on: April 14, 2012 - 11:21:29 PM »
Looks good, thanks
« Reply #10 on: April 17, 2012 - 11:42:55 PM »
No problemo, Here is my current set up, 15x8 front, 4.5" backsace, 26x10x15 S/Rs and 15x10 rear, 5" backspace, 26x12x15 S/Rs.
