Author Topic: installed my water temp gauge on the hood today  (Read 1020 times)
Offline The4ork
« on: April 09, 2012 - 03:11:13 PM »
with my rallye gauges out of commision, only the amp gauge works (stupid things...) i decided i needed to know if my newly rebuilt and running engine was overheating, especially since i dont have a fan shroud.
so this was my solution. a gauge i already had (mechanical) and a $5 gauge holder, 2 screws, and two strips of red teflon about 1/8" thick.
a strip of teflon sits between the gauge holder and the hood, to prevent metal/metal contact and messing up the paint. the strip has two pilot holes drilled through it, and another strip under the hood, with small pilot wholes drilled in it. the two screws run through the gauge holder, the first strip, and grip into the strip under the hood sandwiching everything together in an easy to remove with no damage setup.
not sure if ill get flamed for the hood install... but i thought it was cool and easy to install.
Offline msbaugh
Re: installed my water temp gauge on the hood today
« Reply #1 on: April 10, 2012 - 07:49:35 PM »
I need to mount a temp gauge! My rallye gauges are also broken (I know your pain!) I've resulted to just pulling out a heat gun every now and then to double check everything is ok.  I need to stop being lazy and get them damn things fixed
Offline GoodysGotaCuda
« Reply #2 on: April 10, 2012 - 08:41:51 PM »
Not too shabby, I used an existing windshield trim bolt to secure my mech fuel pressure gauge. Not quite in the line-of-sight, but very easy to see still.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline The4ork
« Reply #3 on: April 10, 2012 - 09:58:39 PM »
beautiful car. wish i had a grill :(
