Author Topic: Throttle cable replacement for 70' Barracuda 318  (Read 1320 times)
Offline Bob_Log
  • Newbie
« on: April 09, 2012 - 07:07:43 PM »
I'm not sure if this is a stupid question or not but I am trying to replace the original throttle cable on a 1970 Plymouth Barracuda Gran Coupe 318.
My problem is the "original" (to the best of my knowledge) cable has this weird square plastic thing surrounding the throttle cable on the inside of the firewall, this plastic piece is not present on the replacement cable or mentioned in the mechanic's manual and is keeping me from taking out the old cable. It originally had a random rusty piece of metal running through it as represented by this rust colored line I drew in paint:
http://krogoth.org/cuda3.jpg
I figured once the metal was removed it would simply slide through the firewall and all would be well, but alas that's not the case. Now it looks like this but still will not push through the firewall in either direction;
http://krogoth.org/cuda22.jpg
This is what it looks like in the engine bay:
http://krogoth.org/cuda.jpg
I've spent an hour trying to break off the little wingtips, trying to force them through, pinch them together, pry them through from the engine bay side and everything short of just taking a hammer and busting the whole thing to pieces.
Offline GranCuda1970
Re: Throttle cable replacement for 70' Barracuda 318
« Reply #1 on: April 09, 2012 - 07:08:48 PM »
welcome to cuda challenger .com  :2thumbs:
« Reply #2 on: April 09, 2012 - 07:11:38 PM »
I left mine in have not taken it out! Is your stickin?
Offline Bob_Log
  • Newbie
« Reply #3 on: April 09, 2012 - 07:13:54 PM »
It's frayed in number of places and many of the strands of metal have started to snap, so it does catch when pushing the throttle more than ~10%.
Thanks!
If anyone has any idea about what I can do it would be greatly helpful as this is my only mode of transport for the momment. I've tried cutting the plastic obviously with little results but the space is very limited.
« Reply #4 on: April 09, 2012 - 10:00:16 PM »
the two "wing tabs" need to be squeezed together to remove it , it will slide out into the engine bay , the rusty metal tab is factory , it prevent it being removed even with the tabs squeezed , I have seen this on a number of cars I have disassembled . Try vice grips to fully squeeze the tabs so it can be pushed out .
