Author Topic: Different springs / weights for stock Distributor?  (Read 586 times)
Offline Glennster
« on: April 09, 2012 - 07:41:03 PM »
  I'm using a stock Mopar electronic ignition system. My timing is 15 at idle and around 36 at the top. I was told that there may be springs that would get my to 20 or 25 at idle. I'd like to get the engine to run a little cleaner at idle and was hoping that this would help.
THANKS for any helpful advise!
Re: Different springs / weights for stock Distributor?
« Reply #1 on: April 09, 2012 - 09:53:01 PM »
the springs change the speed that the advance comes in , heavier springs take more RPM to allow the advance , conversely lighter spring bring the advance in sooner .
 Newer dist built in the last 4-5 years have 2 torx set screws that can be loosened to alow a limiter plate to be adjusted for more or less curve . The older Dist have to be disassembled & the slots welded to shorten the travel .
Offline LAA66
« Reply #2 on: April 09, 2012 - 10:32:12 PM »
 Possibly connecting the vacuum advance to a direct manifold port would help raise idle readings.
