Author Topic: Show me your add on amp locations  (Read 4425 times)
Offline ntstlgl1970
  • T a c o c a t
« on: April 11, 2012 - 01:04:47 AM »
 :feedback:
Trying to find good places to put an amp, was thinking maybe on the bottom of the package shelf or on the backside of the back seat support. Where are you mounting yours??
Offline pywell
  • Autobody Technician
    • PPC Customs
Re: Show me your add on amp locations
« Reply #1 on: April 15, 2012 - 07:33:32 PM »
I havent finished ours yet. I was either going to fabricate a basket/carriage system to support it between the rear speakers in the back if we decided to go with a hidden stereo system, or I was going to make a faux wall between the rear seat supports and the wheel wells to hide that nicely with a color matched metal back and a clear view window to show off the amp and subs while at the same time cleaning up the rear trunk. That maybe hard to visualize. I still have to play with the idea.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Offline 422STROKER
  • Member Since 6/3/06
« Reply #2 on: April 15, 2012 - 08:39:34 PM »
When I took out the speaker box, I mounted the amp to the bottom of the package tray.  Simple and works ok.
Tom
Tom
Offline Grec
« Reply #3 on: May 30, 2012 - 02:18:54 PM »
I've got mine mounted under drivers seat. Wires just run through small hole in carpet and then out to the channel next to door opening. Nice and clean install.
200w Kicker amp.
My seats don't have any spacers on them and it still clears fine. You can't see a thing unless you stick your head in the floor well.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
« Reply #4 on: May 30, 2012 - 04:17:50 PM »
200w Kicker amp.
That's where I wanted to mount mine, but with a six-way seat, it wasn't happening.   :grinno:
I had to mount mine in the trunk by default.
« Reply #5 on: May 30, 2012 - 04:24:13 PM »
Mike, are you bringing the 70 to Carlisle? I'd like to see how the 6 way seats work? We are both tall. I find myself wishing either that the seat would tilt back more or that it would slide back more and give my legs more room.
« Reply #6 on: May 30, 2012 - 06:42:37 PM »
Brad,
  I have my 2009 Chally registered, but I could change that I guess.
The six-way seat allows you to move both the back and the front of the seat up and down. Kinda neat for back then.   :grinyes:
I'll gladly bring my 70 if it makes you happy.    :swaying:
« Reply #7 on: May 30, 2012 - 09:05:29 PM »
Brad,
Do you " fit" better with the 6 way adjustments? Does it make it more comfortable?
« Reply #8 on: May 31, 2012 - 07:46:42 AM »
That's hard to say. I never had the standard two way seat tracks, so I really can't compare the two.
Offline GreenFish
« Reply #9 on: July 19, 2012 - 12:27:51 PM »
200w Kicker amp.
When i bought my cuda 15 yrs ago the PR had an amp under each front seat. Seemed to fit well.
Offline roddil
« Reply #10 on: October 13, 2012 - 05:00:00 AM »
My solution to your question was building this "table" under the package tray.  That allowed me good room to mount amplifier and 6" sub woofer box.  I'm planning to eventually box out my trunk, so when I do, this set up will be hidden from view completely.
