Author Topic: Emergency Brake Cables  (Read 3062 times)
Offline Edison1970
« on: April 11, 2012 - 10:59:17 PM »
When I purchased my car, the entire e-brake assembly was missing.  I found a complete cable kit but it says it is for a 70 cuda.  Will this work for a 72?
Re: Emergency Brake Cables
« Reply #1 on: April 11, 2012 - 11:53:28 PM »
No it won't work.
70 Cuda's & Challengers have a different cable set up.
71 up have a rod that runs off of the trans mount to equalize the pull on each side.
70's don't do this.
« Reply #2 on: April 11, 2012 - 11:58:01 PM »
71' and on...
Offline burdar
« Reply #3 on: April 12, 2012 - 08:47:41 AM »
That picture looks like the cables have been modified for subframe connectors.
Topcat is correct.  1970 is a completely different setup.  Fine Lines sells the correct kits for your car.  At one time, Inline Tube was supplying the wrong length front cables in their kits.  I don't know if this was corrected.
Offline Edison1970
« Reply #4 on: April 19, 2012 - 08:17:47 PM »
Thanks for the replies.  They list with or without intermediate cable.  How do you know which one to choose?
Offline burdar
« Reply #5 on: April 19, 2012 - 08:48:24 PM »
71-74 use the intermediate cable.
I assume the intermediate cable is shorter on the Cuda but if it helps my "stainless" Challenger kit is # BCE02S.  That is from Fine Lines.  I believe they include a new floorpan grommet with their kits now.  Ask to make sure.
Offline mrbill426
    • All Around Mopars
« Reply #6 on: April 29, 2012 - 12:16:14 AM »
I visited Fine Lines' web site and found no brake cables at all, only brake lines.  Maybe I have the wrong link?  :dunno:  I am looking for the front cable for our '72, the one the connects to the brake lever under the dash on one end, and the trangular equalizer on the other.
Thanks
 :working:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline burdar
« Reply #7 on: April 29, 2012 - 12:45:29 PM »
Call them up.  They have brake cables.
Offline Grec
  • The '73 Chrysler should have made...
« Reply #8 on: May 01, 2012 - 12:22:21 PM »
As mentioned, Inline Tube sells a complete set: everything from the pedal to the drake drums.
I just installed this one last year. Very good price and went in perfect.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline mrbill426
    • All Around Mopars
« Reply #9 on: May 05, 2012 - 09:06:49 AM »
Thanks
MOPAR or NO car!
