Author Topic: steering gear box  (Read 2536 times)
Offline Jamie
steering gear box
« on: April 12, 2012 - 08:28:07 AM »
 Hey folks, I have searched the site and cannot find an answer. I just installed a reman power gear box in my 70 cuda, the steering coupler now is to loose. are there different size gear box shafts for different years?I nknow the pitmans can be different, I have a 73 gear box  and   a 70 column. Any thoughts?
I will finish a project.I will finish a project. I will finish a project.
70 barracuda plum crazy
( current goal is to keep just one car) AND FINISH IT!
08 charger r/t  w/road & track package
2011 silverado
Re: steering gear box
« Reply #1 on: April 12, 2012 - 11:15:33 AM »
It is possible to assemble the coupler with the shoes 90* out and it will work, but it will be loose. Check to see if that is the problem.
Offline swede-cuda
« Reply #2 on: April 12, 2012 - 01:51:41 PM »
 :clueless: maybe you have a manual coupler,the manual coupler has bigger dia.  :bigsmile:
« Reply #3 on: April 13, 2012 - 11:47:13 PM »
is the coupler tight on the steering box shaft ? there are 2 different sizes .
 Or is the steering column shaft into the coupler loose there with the coupler tight on the shaft ?
Offline Jamie
« Reply #4 on: April 14, 2012 - 04:06:11 PM »
It is loose where it connects to the gear box. not even close to fitting. I just bought one from chrysler(truck ) and same thing! I caNT FIND ONE ON EBAY eITHER
2011 silverado
Offline coolnorske
  • Newbie
« Reply #5 on: April 15, 2012 - 06:53:57 PM »
There are 2 different sizes, one for power steering (smaller) and one for manual steering (larger) I do have several extras for the power steering (smaller) if you need one, I can let you have it for like $ 10 + shipping
Offline Jamie
« Reply #6 on: April 15, 2012 - 09:50:45 PM »
I sent a p.m.  I will be happy to buy one of the smaller couplers from you!!
2011 silverado
Offline woody02
  • Newbie
« Reply #7 on: April 18, 2012 - 08:59:16 PM »
 i see someone else is having problems finding answers about steering.my 73 challenger w/ power steering has a ton on gearbox play.i have the adjustment all the way. it also has alot of play where the shaft goes into the coupler.where do i buy the items needed to fix. whats intailed in replacing that coupler?
« Reply #8 on: April 18, 2012 - 09:22:30 PM »
Here's a good  coupler how to, ignore the part about the rag-joint not used on e-body's
http://www.buschis-place.de/steeringcouplerrepair.htm
Offline LAA66
« Reply #9 on: April 18, 2012 - 11:29:07 PM »
