Author Topic: R/T standard equipment vs optional  (Read 5811 times)
Offline DMZ73
    • http://www.pbase.com/dmz73/
« on: April 12, 2012 - 08:31:18 PM »
While researching a friends early (October 1969)V code car, I found a few things that didn't quite make sense to me. :clueless: :dunno:
Was a rallye hood standard equipment on an R/T?
Wouldn't it say so on the broadcast sheet?
When you ordered a 4 speed car, was a pistol grip standard equipment?
Does the Pistol Grip get identified on the build sheet only in the case of a 3 speed?
Thanks,
Dan
Offline Super Blue 72
    • Phil's Super Blue '72
Re: R/T standard equipment vs optional
« Reply #1 on: April 13, 2012 - 07:45:03 AM »
Wasn't the 3 speed a black ball shifter knob, not a Pistol Grip?  :clueless:
Offline CarelianCuda
    • http://bot.fi/3gu
« Reply #2 on: April 13, 2012 - 09:03:16 AM »
Yes it was.
Quote
Should be, if they have remember to put it on or some times they have put it on tag too, see these two examples:
No J54 tag or sheet: http://www.arts-attic.com/automobiles/70challenger/70challenger.htm
J54 on tag: http://www.pantherpink.com/fm3004.htm
I can't see any other clue why it's some times and some times not?
Quote
 Yes.
Quote
Pistol grip not available with 3 speed at all.
-Juha
1970PlymouthCuda383 FY1xE63xD32xA36xA62xB51xH51xP31xY22.........
2003TruckmastersOkenosDurangoSlt+ PRVx4.7x545RFExNV244x3.55xLSD
Offline DMZ73
« Reply #3 on: April 13, 2012 - 05:37:51 PM »
Ok..so dumb question.
This 440-6 pack R/T car I am researching is an oddball to the rule, following the one example you cite.
The J54 is not on the fender tag, and it's not on the build sheet, as described.
Was there ever a case where an R/T car could have come with a flat hood?
Dan
Offline 440magnum
« Reply #4 on: April 13, 2012 - 06:03:36 PM »
My car was built in oct-69 and it has the original R/T hood on it but there is no code for it on the FT nor on the build sheet :2cents:
« Last Edit: April 15, 2012 - 06:01:39 AM by 440magnum »
70 R/T U-code, D21 4 spd, A33 dana
Offline ChallengerHK
« Reply #5 on: April 13, 2012 - 06:07:17 PM »
My thought on this is that anything could have been built as a option-delete, so I'm sure that the R/T hood could have been deleted in favor on a flat hood. The next question is, where would that show in the paperwork?
- Han Solo, Star Wars
Offline Jamiez
  • Retro
« Reply #6 on: April 13, 2012 - 06:26:54 PM »
Does a stock 440-6 pack with stock intake/air cleaner fit under a flat hood?
Offline 7071 challenger
  • All you need is Dodge!
« Reply #7 on: April 13, 2012 - 06:55:02 PM »
Good point. I don' t think so. That is probably why all Hemicudas & 440-6 Cudas came with shakers (the rallye hood on Cudas are lower the those on Challys). And I don't think you could have a 3 speed behind a 440-6. Bottom line, the rallye hood was standard equipement on any R/Ts. Optional was the shaker hood (N96) and I head that a few R/Ts came with T/A hoods, (N94).  On my 71 R/T, code J54 appears on the fender tag and on the built sheet as well.
Robert
« Reply #8 on: April 13, 2012 - 07:09:55 PM »
Dan, from the nature of your questions, I assume that your friend is not the original owner, but that he'd at least like to believe the car is unmolested?
Offline JH27N0B
« Reply #9 on: April 14, 2012 - 08:14:16 PM »
Robert
The shaker hood was standard on hemi cudas but not V code cudas.  I've seen a couple V code cudas with original rally hoods, though most seem to have shakers either originally optioned or added to the car later.
http://www.classyauto.com/v/plymouth+cuda/440+six+pack,+rare+v+code,+sport+hood/65955
« Last Edit: April 14, 2012 - 11:24:11 PM by JH27N0B »
« Reply #10 on: April 15, 2012 - 08:20:10 AM »
First time I see one 440-6 'Cuda without a Shaker hood...   Hey, I never said I was perfect!   Oh Well...
Robert
Offline Sleepychallenger
« Reply #11 on: April 15, 2012 - 10:02:59 AM »
Mine is a factory R/T with a flat hood. It is an oddity though. Mine came with the flat hood, no R/T badge on the trunck and no wood grain in the door panels. My dad bought the car in 76 and remembers when the original owner bought it. He can't remember the reason it came with the hood it did but remembers that's the way it came crime the dealer. It is a oct or nov 69 build car
« Reply #12 on: April 15, 2012 - 11:43:12 AM »
You can tell the built date if you have the fender tag. On the second row, (from the bottom), your 4th code, (from left to right), is the built date.  It is a 3 digit code that will start with 12 possibilities, (month), followed by day. 1=January, 2=february, 3=mars, 4=april, 5=may, 6=june, 7=july, 8=august, 9=september, A=october, B=november, C=december. For exemple, 219 would be february 19, or B23 would be november 23. Would love to see the built sheet from your car.
Robert
Offline DMZ73
« Reply #13 on: April 15, 2012 - 12:12:09 PM »
Wow! Great responses!
My friend pitted this car in the 70s/early 80s and purchased the car from the racer (Craig Cates) at the time.
I believe the racer may have been the original owner, or at the least, the second owner.
The car is a 70 V-code 440-6 pack, 4 speed Dana track pack car.
The car has an original shaker hood on it right now, and since his car is not coded for it, we both wondered what hood originally came on the car.
Since I decoded the build sheet, I can't seem to figure out this lil anomaly.
Is there any documentation to verify that V-code cars come standard with shakers or rallye hoods?
This certainly would be an oddball if it were a flat hood car.
I have to ask him if he has the fresh air control for the interior.
I will edit his build sheet to remove some info, and post a pic or two.
Dan
« Reply #14 on: April 15, 2012 - 03:41:32 PM »
Robert
If there were a build sheet I would post it up. It is an LA car and most of those don't have the sheets. Tag says B10
