Author Topic: Anyone Running a 285/40/17 in back  (Read 1231 times)
Offline bigblue73
« on: April 12, 2012 - 09:23:15 PM »
Is anyone running a 285/40/17 on the rear of their Challenger?  My 275's are weather checked - Not sure why - but they are getting replaced.  In looking I've got more than 5/8" each side spring and molding to fit the 285's.  The reason I'm asking is that I see that Nitto makes a 285/40/17 which has a nicer 4 1/2" side wall height and comes in at 26.00 inches tall.  My Challenger has the stock rear width and stock spring locations.
Thanks -
Offline 73restomod
Re: Anyone Running a 285/40/17 in back
« Reply #1 on: April 16, 2012 - 08:08:19 PM »
I am, but my car has a B-body rear,which gives me an extra inch of BS over a E-body. I tried a 5 1/4 BS first, which left me with a half inch to the lip (unrolled). I switched to a 5 3/4in BS (both on a 10 inch rim) and it gave me the clearance I was looking for at the outer lip. _However, my BS is so tight I will HAVE to run a 1 inch relocation kit from Doctor Diff to ensure no leaf spring rubbing.
Offline Grec
« Reply #2 on: April 18, 2012 - 08:52:28 AM »
Every 10mm of tire width is approx 1/3"... so if you've got 5/8 on each side, from tire to fender lip and from tire to springs, you should be fine going from 275 to 285.  :thumbsup:
« Last Edit: April 18, 2012 - 08:54:19 AM by Grec »
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline bigblue73
« Reply #3 on: April 20, 2012 - 09:59:07 AM »
I pulled the trigger on the 285's - I figured the .393 inches / 2 or approx .200" inches per side would not kill me and I get the tire height that I'm looking for.  I'll post them up when they are mounted.  Thanks -
Offline bigblue73
« Reply #4 on: April 27, 2012 - 04:19:04 PM »
Well I have them mounted and they are awesome.  Pictures soon.
Offline bigblue73
« Reply #5 on: May 08, 2012 - 08:10:12 AM »
Video - Wait till the end.  That is some beefy tire.
Illumin8s Challenger Drive By
Thanks for the help!
Tony
