6.1 Hemi Conversion A/C adding questions.
Author Topic: 6.1 Hemi Conversion A/C adding questions.  (Read 3784 times)
Offline pywell
  • Autobody Technician
    • PPC Customs
« on: April 15, 2012 - 07:17:48 PM »
We are installing a 6.1 hemi in our 74 Challenger. Has anyone added A/C? The car is originally not with A/C and I am trying to figure out what I need to piece together to get it all going. Im hoping that someone has done this or at least put enough thought into it to get me started in the right direction.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: 6.1 Hemi Conversion A/C adding questions.
« Reply #1 on: April 15, 2012 - 07:26:49 PM »
I would use a kit like this one if I were doing a non ac car http://www.vintageair.com/catalog11/pg31wc.pdf
Go Fast & Have Fun...
Offline pywell
    • PPC Customs
« Reply #2 on: April 15, 2012 - 08:41:43 PM »
Looks very promising I will have to check that out. thanks for the link. It looks very well done and complete. Has anyone on this board used this kit at all?
Offline Travis72
« Reply #3 on: April 15, 2012 - 11:22:23 PM »
I have one and it's a nice kit, but don't have the AC lines hooked up yet.  I bought the kit without the compressor and instead bought a compressor from a 5.7 hemi car from a recycling yard for cheap.  Mine is a semi-custom install.  The Vintage air kit is meant to go through the hole where the factory blower motor was, but I'm trying to hide the lines.  Anyway you can check out install pictures in my thread (page 21):
http://www.cuda-challenger.com/cc/index.php?topic=28465.0
Travis
72 Cuda
Offline pilotusmc
« Reply #4 on: October 20, 2013 - 05:15:14 AM »
I put a  6.1 in  my challenger.  I used the stock a/c compressor.  You have to knotch the frame and cut the  back  mount off the compressor to make it work but it will.   I used  a  2006  Dodge Charger  condensor ..it mounted  great in front of the  radiator.  Had  to make  small modifications to the  radiator support but it is obvious what needs to be  done when you do this.
This  allowed me to use the  2006  hemi  a/c  lines also... I  trashed the  huge 70  ac  can under the dash and went with the classic auto air one...some mods to hook up the evap.....I have photos....  email me pilotusmc@aol.com
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #5 on: October 20, 2013 - 09:32:06 AM »
I just used the front engine accessory kit from BPE , The compressor mounts on the drivers side with no interference . http://www.bpeusa.com/61LHemiFKIT.asp
Offline pilotusmc
« Reply #6 on: December 28, 2013 - 02:44:58 AM »
I am using the  Vintage AUTO  AIR  system....using  my stock compressor from the 6.1 hemi.....stock  2006  Dodge Charger  condensor....The  condensor  fits  great in front of the  radiator with minor mods to the radiator support...looks  nice....I have the hoses from the  2006  charger  and a local company here  made me  custom hoses using the ends form my stock hoses....have not fired it up yet but  looks great
« Reply #7 on: December 28, 2013 - 06:46:55 AM »
Sounds interesting . Any pictures?
