Author Topic: Could lower octane gas cause an off-idle stumble?  (Read 3720 times)
Offline Grec
« on: April 16, 2012 - 12:16:33 PM »
Drove the Challenger into work this morning and noticed a very definite off-idle stumble. The only thing I can think of that changed was that I put in some lower octane gas recently. I usually run premium. (Yes. I was being cheap. Premium is $4.40 a gallon here.)
Other than the stumble, she seems to be running normally once you get the RPMs up.
Could gas alone cause something like this?
440 Six-Pack, stock Mopar electronic ignition. Fairly new plugs, stock heat range.
Thanks.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Re: Could lower octane gas cause an off-idle stumble?
« Reply #1 on: April 16, 2012 - 04:18:41 PM »
Did it run fine before putting in the cheap gas?
I would expect a pinging problem, not a stumble off idle. I'm no gasoline expert though.
Offline Grec
« Reply #2 on: April 16, 2012 - 04:35:06 PM »
Yeah. It was running fine before. At this point, unless you give it more gas, she feels like she's gonna stall. :-\
- 440 Six Pack
Offline spamtank
« Reply #3 on: April 16, 2012 - 05:40:19 PM »
I have the same problem.  I figured my accelerator pump rubber was eaten away by the ethanol in the gas.   :dunno:
I'm planning a carb rebuild later this spring/summer.
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Offline LAA66
« Reply #4 on: April 16, 2012 - 10:36:58 PM »
 Lower octane should not cause a stumble unless you were way lean to begin with.
Offline jimynick
« Reply #5 on: April 16, 2012 - 10:50:07 PM »
Good luck with the stumble, but before you feel too bad about using that cheap gas- it's now $5.56 a gallon for 87 octane here in the Frozen North and 91 is probably another $1.00. Believe it or not.  :swear:
Offline 72bluNblu
« Reply #6 on: April 17, 2012 - 12:18:34 PM »
I'm with MEK and LAA66, the lower octane shouldn't cause an off idle stumble. If it were detonating because of the lower octane it would get worse as you gave it more gas, not better.
And, as long as its not detonating, a higher octane fuel doesn't really do anything for you performance wise. You're better off running the lowest octane fuel your engine can handle without detonation. "Extra" octane is basically a waste of money.
But, you could be getting that off idle stumble because of bad fuel, which you may have gotten if you filled up somewhere cheap. Or, it may have a higher ethanol content than what you normally run, and that could cause you some issues.
Offline Grec
« Reply #7 on: April 17, 2012 - 01:34:21 PM »
Thanks for all the responses...
Brief update: I drove her home from work, which is about 30 miles, and the problem only got worse.
At this point, it feels like she lost a cylinder, or two. Gonna check the plugs and all that as soon as I get some time.
Just when I got the suspension replaced and dialed in... Damn cars! Lol.
- 440 Six Pack
Offline dutch
« Reply #8 on: April 17, 2012 - 03:04:23 PM »
we`ve still got 95 as regular.  bad part... it sells @ $10,80 a gallon   :1zhelp:
*** Bart ***
Offline 73Chally
« Reply #9 on: April 17, 2012 - 05:34:28 PM »
Sounds like bad gas.  Have you tried topping off with 91/93, or whatever your highest Octane available is?  After 30 miles, I would think you should be down at least a quarter tank.  Could also be water in the gas if the gas station tank was low.
« Reply #10 on: April 17, 2012 - 07:27:45 PM »
I'm finding ethanol makes the fuel boil in the carb at a lower temperature than with no ethanol , in addition to rotting anything rubber. :banghead:
Water in the fuel will also cause a stumble?
Offline LAA66
« Reply #11 on: April 17, 2012 - 10:27:30 PM »
 My thoughts about the water issue also. Perhaps, there was a tanker filling at the time or just prior.  They boil up the stuff from the bottom.
« Last Edit: April 20, 2012 - 11:38:23 PM by LAA66 »
« Reply #12 on: April 19, 2012 - 12:05:43 PM »
I had a similar issue years ago , only one gas stn open & it had high ethanol  content , I thought I had hurt the engine towing [440 Power Wagon] , it was tuned on zero ethanol fuel , filled it back up with good fuel & the problem vanished . I am sure I could have tuned it to work on the crap fuel but why bother !!
Offline LAA66
« Reply #13 on: April 19, 2012 - 10:42:32 PM »
 If anyone's interested here is a way to state your opinion.
 http://capwiz.com/amacycle/issues/alert/?alertid=61221996&queueid=[capwiz:queue_id]
Offline LAA66
« Reply #14 on: April 20, 2012 - 11:46:27 PM »
 Hopefully some have made the effort to contact their representative.  :wave:  We have had luck with these notifications in saving off-road riding areas so it is worth while.
