Author Topic: 70 Barracuda 383 resto project  (Read 4996 times)
Offline painterjohn
  • www.airbornekustomz.com
    • Airborne Kustomz
« on: April 16, 2012 - 04:28:27 PM »
Hey Guys,
I just joined this site about 4 hours ago, made my introduction in the newb section.
I am restoring a 70 Barracuda for a long time friend/customer of mine. The car has been in his family since 1974, but has not moved (until friday) since 1977.
I really want him to spend the money to put it back as close to original as possible, but it is missing the original engine and transmission. And the evidence kinda shows this car was bastardized many years ago. Big hole cut in one of 2 hoods and a fiberglass prostock looking scoop added. OEM wheels are gone, nice 14" x 10" Aluminum Slots in thier place. Body work and repaint evidence all over it, engine compartment looks to have been spray painted black at some point (unless that was an OEM kinda thing, I really doubt i tho)
Steering center link was cut and a U welded in to it (he was told his brother was attempting to install a 426 when it was parked for good)
Anyway.
I am trying to decipher the fender tag using the lists I have found here, but im coming up short on a few numbers. I was wondering if anyone would like to help out the new guy
26 EN1
L31 M21 N41 R11 V5W Y05
EV2 A01 C16 C55 G36 H51
EV2 H6XW 000 916 014121
E63 D21 BH23 NOB 124183
Offline Jamiez
  • Retro
Re: 70 Barracuda 383 resto project
« Reply #1 on: April 16, 2012 - 05:21:48 PM »
Just using an online decoder:
E63   383-4 Barrel
D21   Heavy Duty 4-Speed Manual Transmission
BH23
B = Plymouth Barracuda
H = High
23 = 2 Door Hardtop
NOB
N = 383 330HP OR 335HP 1-4BBL 8 CYL
0 = 1970
B = Dodge Main, Hamtramck, MI, USA
124183   Sequence Number '124183'
EV2   Paint Code: Hemi Orange / Tor-Red Irid
H6XW
Trim Grade/Style/Color
H = High
6 = Vinyl Bucket Seats
X = Black
000   Upper Door Frame: Full Door Panel
916   Date Built: 9 / 16 / 1969
014121   Order Number: 014121
EV2   Roof Type OR Color:  Hemi Orange / Tor-Red Irid
A01   Light Package
C16   Console w/ Buckets
C55   Bucket Seats
G36   Left Hand Remote, Right Hand Manual Outside Mirror
H51   Single Air /w Heater
L31   Hood / Fender Mount Turn Signal
M21   Roof Drip Rail Moldings
N41   Duel Exhaust w/o Tips
R11   Music Master Radio AM
V5W   White Vinyl Stripe
Y05   Built to U.S. Specifications
26   26 in. Radiator
EN1   End of Codes Assembly Line 1
Offline CarelianCuda
    • http://bot.fi/3gu
« Reply #2 on: April 16, 2012 - 05:50:47 PM »
 Few fixing after online decoder:
N = 383ci 330HP 1-4BBL 8 CYL
H6XW
H = High
XW = Black & White
916 =  Scheduled Built Date: 9 / 16 / 1969
G36 =  Left Hand Remote, Right Hand Manual Outside Racing Mirrors, Body Color.
V5W = White Body side protective moldings with vinyl insert.
 1970 Barracuda models had a painted pinstripe included with the V5 moldings that was the same color as the insert
http://www.hamtramck-historical.com/colorsExt/colorsExt.shtml
1970PlymouthCuda383 FY1xE63xD32xA36xA62xB51xH51xP31xY22.........
2003TruckmastersOkenosDurangoSlt+ PRVx4.7x545RFExNV244x3.55xLSD
Offline painterjohn
    • Airborne Kustomz
« Reply #3 on: April 16, 2012 - 05:57:48 PM »
WOW thanks yall!
So this is not the special 335 HP 383? Basically the engine should be blue?
Would that be the Black stripe from the rear of the quarter forward? or literally just a pinstripe?
Offline Culvers
« Reply #4 on: April 16, 2012 - 06:13:26 PM »
V5.. looks like this
    • http://bot.fi/3gu
« Reply #5 on: April 16, 2012 - 06:14:23 PM »
Check EV2 color of that Hamtrack-link, there is picture of V5W. (Hockey stick stripe is V6X)
N-code engines on BH (Barracuda) & BP (Gran Coupe) models have 330hp and on BS ('cuda) models 335hp.
I think at it's blue even with manual trans because of A/C.
I've heard orange engines with manual trans without A/C, but can't remember saw any.
Offline painterjohn
    • Airborne Kustomz
« Reply #6 on: April 16, 2012 - 07:12:39 PM »
cool thanks again!
This one did not have A/C.. no condenser, no lines, no evap, nada.. Heat and outside air only.
Offline painterjohn
    • Airborne Kustomz
« Reply #7 on: April 16, 2012 - 07:14:09 PM »
What is that on the rockers? Was that part of the V5W trim also? Looks like louvers...
    • http://bot.fi/3gu
« Reply #8 on: April 17, 2012 - 04:51:21 AM »
H51 = A/C. Check the firewall holes.
"Fish gills" rocker moldings are std on -70 'cuda (except AAR), not available for other models or years.
Hockey stick stripes are also only -70 'cuda thing, forgot to mention earlier.
Offline ragtopdodge
« Reply #9 on: April 17, 2012 - 11:44:39 AM »
Cool car.
I would leave off that body side moulding.  Ugly IMHO.
Yes, you definitely have AC.  Just all the lines and compessor removed, but I'm sure you still have the AC lines from the heater box poking through the firewall.  Don't get rid of it.  AC plus 4-speed is cool!
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline painterjohn
    • Airborne Kustomz
« Reply #10 on: April 19, 2012 - 06:03:53 PM »
the moldings and the rocker lovers are gone. Found out a bit more about the car. In 1975 it went through a house, backwards! The guys were tinkering with it started it through the window, it was in reverse and it blasted its way through the front of the house! That explains the quarter panel repair and over all paint job.
There are no A/C lines or even extra holes on the firewall.. if someone took it out, they covered the holes nicely.. Which might explain the black paint in the engine compartment.
Offline painterjohn
    • Airborne Kustomz
« Reply #11 on: April 19, 2012 - 06:07:09 PM »
here is a couple of decent pictures of how it sits right now
Offline Katfish
  • 70 Challenger
« Reply #12 on: April 19, 2012 - 06:19:33 PM »
Definitely not a AC firewall, might have been changed, but doubtful.
Offline ragtopdodge
« Reply #13 on: April 20, 2012 - 11:44:32 AM »
Ya, either the firewall got changed, or the whole car is a re-body. :22yikes:
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline painterjohn
    • Airborne Kustomz
« Reply #14 on: April 20, 2012 - 04:58:10 PM »
I really doubt that it was changed.. Is it possible that plymouth stamped the data plate wrong? I suppose the holes could have been welded up, and then painted over, since the rest of the engine compartment is black..  :poopoke:
