Author Topic: Non-Power master cylinder install ?  (Read 926 times)
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« on: April 17, 2012 - 03:14:42 PM »
Installing the brakes and a new master cylinder this week. Need to know what gaskets are supposed to be where. There is the firewall, then the plate thing where the shaft goes through, and then the cylinder itself. Are there foam gaskets that are supposed to be installed on both sides of the mounting plate? One side?
Offline mopar397
Re: Non-Power master cylinder install ?
« Reply #1 on: April 17, 2012 - 06:34:31 PM »
just the side against the body i believe.. its just sealing between the two so water or anything doesnt get inside the car
Offline peterro
    • The Pistonhead
« Reply #2 on: April 17, 2012 - 11:59:36 PM »
Well I found the 2 gaskets. One for firewall to plate and the other for plate to master cylinder.
Thanks.
