New spare tire idea
Author Topic: New spare tire idea  (Read 11767 times)
Offline Jim
New spare tire idea
« on: April 19, 2012 - 01:20:31 PM »
Here is something I’ve been toying with on and off over the years.
For those that don’t see the value of a functional spare tire, move along. You either don’t drive your car much, or never venture to areas where roadside assistance and cell phone service is sparse. Or you just like living dangerously. That’s cool. That’s your choice. I’m not looking to debate that point here. If on the other hand, you do prefer to have a good spare in the trunk like I do, read on. You might find this interesting.
One of the challenges I’ve run into after installing aftermarket tires and wheels on my Mopars is having a spare tire that closely matches the rear diameters. This is critical if you have a sure grip differential and don’t want to wear out the clutches in short order.
Just mounting the same size tire as the rears on a spare wheel doesn’t work. Many of the popular sizes won’t fit in the trunk, or function as a front tire. Truck space is at a premium in E-bodies, so even if they do fit, you’re left with very little space for anything else. They also can be really freaking heavy, weighing about 60 lbs in some cases.
Another potential issue is brake clearance if you are running larger than stock brakes.
Two of the most popular rear tire sizes are 255-60-15 and 275-60-15 with diameters of 27 and 28 inches respectively. Those are relatively tall tires, and their widths make it impossible for them to fit under the package tray in the trunk storage location.
So the challenge is finding a narrower tire with a similar diameter. There really isn’t much out there. Some 70 series tires come close, but the cost of a new tire and hassle of cleaning up a crusty wheel got me looking for other options. That led me to start looking at late model compact/temporary use spares.
While most “donuts” are way too scrawny, a lot of SUVs are now coming equipped with a 155-90-16 as a spare. These measure out just shy of 27 inches in diameter. Perfect relative to the 255, and probably as close as you’re going to get to the 275.
The bigger challenge is finding a wheel for it. All of the tires I’ve found in this size come on a wheel with a ton of positive offset which just won’t work. Jeep Cherokees are a good source for the tire (note that some have a 125-90-16), and have the correct bolt pattern, but the wheel has about 3 inches of offset and it contacts the brake drum preventing the wheel from seating on the drum face in some cases. I’ve actually used one of these spares with wheel spacers, but it’s not a very elegant solution.
Searching for another 16-inch spare with the correct bolt pattern and less offset I found the spares used in Ford Crown Vic, Mercury Marquis and Lincoln Town Car. The later model years of these come with a 16x4 steel or 16x4.5 aluminum spare. These appear to have less than an inch of offset. Tire size is scrawny at 145-80-16 (25 inches), but it’s the wheel I’m after. The Town Car is your source for the aluminum, which is what I chose to test.
Anyone who as ever tried to install an OEM Ford wheel on a Mopar knows that the center register is too small in most cases. These spares are no exception. A few minutes with a die grinder takes care of the issue though. Only a couple thousandths need be removed, so I took my time and test fitted frequently.
After getting the wheel to bolt up, I made a trip to my local used tire store with both the Lincoln TC spare and Jeep Cherokee spare. For $10, I had the tire from the latter mounted to the wheel of the former.
What it yields is a compact spare perfect for a Sure Grip equipped Mopar. The aluminum wheel looks pretty trick. The whole thing weighs under 40 lbs, which is a modest ten pound savings over at typical conventional spare. I definitely wish I would have had one of these for the space savings in the trunk of my Challenger on the Power Tour a couple years ago. I’d like to have tested it over the 13 inch Cobra brakes on the Cuda I use to have.
While this spare might a solution to a number of problems, there is one it won’t solve. If your 275-60-15 goes flat, after you install your spare, you still have to figure out where to carry that flat tire. It’s not going to fit in your spare tire storage location.
I’ve probably got $70 invested in this exercise. Both the wheels came off Ebay, but a trip to the local salvage yard may have yielded both for less than what I paid.
The Ford “Panther” series cars are the only ones I’ve found with the needed wheel size, offset and bolt pattern. I think there maybe some obscure Mustang or Thunderbird spares as well.
There are a lot more sources for the tires: Jeep Cherokee’s, Honda Pilots, GM S-series pick-ups, and some GM SUVs. I’m sure there are others. Small to midsize SUVs seem to be the best source.
Posted are some pictures showing the examples and results. Standard disclaimers apply. This has only been tested on my 72 Road Runner with factory discs and drums. Sorry, no pictures of it installed on the car. I'll try to add one later.
« Last Edit: April 19, 2012 - 05:48:03 PM by 471_Magnum »
-Jim
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. "
Offline dutch
Re: New spare tire idea
« Reply #1 on: April 19, 2012 - 01:55:42 PM »
I like that  :2thumbs:  thanks for sharing  :cheers:
*** Bart ***
« Reply #2 on: April 19, 2012 - 02:11:22 PM »
I used to have an 82 Cordoba with factory 15" steel wheels.  The car came with a donut spare that was taller then most.  I think I ended up tossing it.  That would probably work too.  I never did measure the diameter though.  I wonder what size spare came in the Diplomats and 5th Ave's of the late 80's?
Offline Jim
« Reply #3 on: April 19, 2012 - 02:20:44 PM »
Those would have been 26" max.
-Jim
« Reply #4 on: April 19, 2012 - 02:58:52 PM »
Great info! Thanks!  :clapping:  I'll have to head to the wrecking yard!  :working:
I have the original spare in there now and could always use the extra room....and less weight is always great too!
« Reply #5 on: April 19, 2012 - 03:13:14 PM »
Quote
Then it would have worked perfectly for an F70x14 tire.  I shouldn't have tossed it.
Offline Jim
« Reply #6 on: April 19, 2012 - 04:08:27 PM »
I say 26", but probably less. The vast majority of those cars had open diffs, so the roll-out wasn't a concern.
-Jim
« Reply #7 on: April 19, 2012 - 05:22:41 PM »
This is a really good idea. This same bolt pattern is also used on various models from Acura, Infiniti, Hyundai, Rover, Lexus, Mazda, Mitsubishi,Nissan, Subaru, and Toyota. No doub tyou can find a few of any of these in a yard somewhere close. Then, like outlined, find one with an offset and width you can live with.
Offline Jim
« Reply #8 on: April 26, 2012 - 06:56:12 AM »
Here's some pictures of it mounted up.
Front of the car is resting on jack stands, so the rear is up a bit. Not much room in the garage to get the shot. Sorry.
-Jim
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #9 on: April 26, 2012 - 07:47:17 AM »
Nice info!  Thanks for sharing it!  :thumbsup:
« Reply #10 on: April 26, 2012 - 06:09:11 PM »
Thanks for the info!  :2thumbs:
You really like being prepared! A spare torsion bar in the trunk too!
Offline Jim
« Reply #11 on: April 26, 2012 - 08:46:45 PM »
That's just a wooden prop-rod for my hood.
-Jim
« Reply #12 on: April 26, 2012 - 08:54:49 PM »
What years and models do the aluminum rim come from? And same question for the Jeep tire?
Thanks!  :2thumbs:  I'm on the "hunt" now!   :grinyes:
Offline Jim
« Reply #13 on: April 26, 2012 - 10:12:52 PM »
The Jeep spares were used for a very long time. Not sure what drive train triggered the 155 vs the 125 though. Pretty much any GC in the last ten years or more will have one.
The TC spare is like 2002 up. Just have to poke around a bit.
-Jim
« Reply #14 on: April 26, 2012 - 10:14:27 PM »
Great thanks!  :2thumbs:
