Author Topic: what type of gear oil to use?  (Read 1597 times)
Offline 70plumchallenger
« on: April 21, 2012 - 07:07:45 PM »
Any recommendations on the the gear oil to use for a 8 3/4 rear axle on a 70 Challenger? Also, I heard that Redline MTL is good to use in A833 transmission...any input is greatly appreciated..thanks
Offline 4 speed fish
Re: what type of gear oil to use?
« Reply #1 on: April 21, 2012 - 07:12:33 PM »
I use 80-90 wt for the tranny.Same thing for the rear end if it is not a posi.I used redline once Imo there was no difference between that and the 80-90 weight for the tranny.
« Reply #2 on: April 21, 2012 - 07:19:30 PM »
Thanks for the info!
« Reply #3 on: April 21, 2012 - 09:09:53 PM »
I use Amzoil Severe gear synthetic. If that pic is your car, you have an awesome Challenger 70plum!  :2thumbs: :2thumbs:
Offline BIGSHCLUNK
« Reply #4 on: April 21, 2012 - 10:08:31 PM »
I've been using royal purp. Great shot of your car!!
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #5 on: April 21, 2012 - 11:08:51 PM »
I have be cautioned from using syn gear oils in the diff although I personally have not had problems , I use 80/90 for the diff with a friction modifier fo rthe sure grip & 80/90 or Redline MTL for the trans , MTL is lighter & should yeild slightly better milage
Offline BS CUDA
« Reply #6 on: April 21, 2012 - 11:46:54 PM »
 I work in a specialty gear shop - with limited slips we only use 80w90 with a friction modifier. We do not have lube failures or premature disc or cone failures. Most aftermarket limited slips also say NO synthetic oils.
Offline wally426ci
    • maryland mopars
« Reply #7 on: April 22, 2012 - 08:31:27 AM »
Bookmark for my 4 speed truck and all my rears.   :popcorn:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #8 on: April 22, 2012 - 10:31:58 AM »
Thanks for the recommendations. I will go with 80w90 with friction modifier for the diff, and Redline MTL for the trans....thanks for the comments on my ride. just got it last July and having a blast!  :burnout:
« Reply #9 on: April 23, 2012 - 10:03:24 AM »
Great looking car , Glad you are having fun with it  :2thumbs:
