Author Topic: Adjusting valve lash...did I do it the right way?  (Read 811 times)
Offline Super-G
« on: April 22, 2012 - 12:34:27 PM »
I have a 69 440 HP motor in my 73 Challenger. It has 906 heads with a hydraulic cam. Don't know the specs on the cam but it's not a stocker. I'd say about half way between totally radical and bone stock. A nice lope but still pulls nice vacuum.
The motor has great oil pressure and pulls strong.
I've noticed slight valve tapping sounds coming from under the passenger side valve cover. I popped it open and found adjustable rocker arms with some slight play in some of them.
Now I've adjusted rockers before but never on a Mopar.
The method I've used is to roll the motor over until the particular cyl is on the compression stroke. Then I tighten the rocker down until the pushrod starts to drag and go another 1/4 turn. I did that on all the rockers and fired the motor up. The ticking was gone until it came up to temp and I drove it around the block.
I'm thinking that the adjusting assy's are older and coming slightly loose?
Any additional thoughts?
Greg
73 Challenger 440 6 pack, 4 speed, 8-3/4 rear w/4:10's.
Offline 72cudamaan
Re: Adjusting valve lash...did I do it the right way?
« Reply #1 on: April 22, 2012 - 12:40:53 PM »
Tighten 1/2- 3/4 turn
If I cant fix it, it's broke
Andy  (phukker whither)
Offline LAA66
« Reply #2 on: April 22, 2012 - 11:34:42 PM »
Running about 1/2 turn here.  A 3/8"- 24 thread = .042" per revolution.
