Author Topic: Best engine adhesive?  (Read 5748 times)
Offline shatar4
  • 71 Challenger
« on: April 22, 2012 - 01:08:26 PM »
Just had my engine rebuilt and about to put all the sheet metal back on and was wondering if anybody had a suggestion on the best engine sealer for the oil pan, water pump cover, etc... Once the motors back in, I don't want it to be leaking all over the place. Thanks
« Last Edit: April 25, 2012 - 06:27:17 PM by shatar4 »
1971 Triple black 340 Challenger
Offline 72cudamaan
Re: Best engine adhesive?
« Reply #1 on: April 22, 2012 - 01:43:07 PM »
Gaskets, with a minimal amount of permatex ultra black for the corner joints. I also use a very small amount of weatherstrip
adhesive to hold the intake gasket,oilpan gasket and valve covers in place. Let the gaskets do their job. You can
usually assemble 4-5 engines with a tube of silicone when used properly.
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #2 on: April 22, 2012 - 11:54:15 PM »
Right Stuff , you don't even need a gasket it is awesome but not cheap .
Offline shatar4
  • 71 Challenger
« Reply #3 on: April 25, 2012 - 05:57:57 PM »
So if I use Right Stuff, I shouldn't use the gaskets?
Offline diyhemi.com
  • Formerly Yellowfin
    • DIYHEMI.COM
« Reply #4 on: April 25, 2012 - 09:13:32 PM »
Ford actually has their own RTV that is very impressive. You can buy it from the dealer and I highly recommend it. It was designed for their diesel trucks and is used on the trans pan as one of its applications. After working at a diesel shop for several years I have seen this stuff work wonders.
1970 Barracuda Gran Coupe, gen III project (Cone Killing Cuda)
« Reply #5 on: April 25, 2012 - 11:08:02 PM »
I would still use gaskets , but it is good enough to get by without
Offline wally426ci
    • maryland mopars
« Reply #6 on: April 26, 2012 - 08:12:40 AM »
This?
http://www.permatex.com/brand_right_stuff.htm
i still have a terribletrans leak after all of my troubles
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline moparclown
« Reply #7 on: April 26, 2012 - 08:32:29 AM »
I agree 100% and would suggest using the gaskets also.
Wally426ci
I have the 904 pump pressure maxed right out in my 69 Cuda and have no leaks at all.
It is $$$$ but I can't see taking a chance with my engine/trans as those were way more $$$$$ than a can of sealant.
Doug
I just put a brand new oil pan on 7.3 Ford diesel using this stuff with no leaks and if you know anything about the pan job on these?the dealer wanted $2500 to do it as you would have to pull the engine out to replace.
Offline wally426ci
    • maryland mopars
« Reply #8 on: April 26, 2012 - 09:31:13 AM »
Wally426ci
Doug
Good to know. I'll be getting this for sure. Pain to know I worked on it for little bits of time over a month and it still leaks!!  :stomp:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline diyhemi.com
    • DIYHEMI.COM
« Reply #9 on: April 26, 2012 - 09:54:25 AM »
Right stuff is the same as ford grey RTV. I recommend as well!
Offline PlumCraZRT
« Reply #10 on: April 29, 2012 - 01:44:52 AM »
*Insert obligatory "Ford parts in a Chrysler car" comment*
mmmmm.... Mopar.... *drool*
Offline shatar4
  • 71 Challenger
« Reply #11 on: April 30, 2012 - 11:22:16 AM »
So I can use it on the intake on the ends?
« Reply #12 on: April 30, 2012 - 08:12:04 PM »
yes  :2thumbs:
Offline 73EStroker
« Reply #13 on: May 01, 2012 - 10:52:11 PM »
CP got it right - called Right Stuff - and horribly expensive but it works. Fixed all my leaks and does not harden so easy to get things off later.
Barry (Salmon Arm)
Offline Travis72
« Reply #14 on: May 02, 2012 - 12:18:34 AM »
Another vote for the Right Stuff!
Travis
72 Cuda
