It does sound like you may have a miss matched set up there, or you hadn't slid the rotors and seal up all the way to the backing plates. If the bearings did fit in your races correctly, you also need to check the I.D. of the bearing and O.D. of the spindal. I believe there are around 3 different sizes between yr models of A B and E body front spindals. If not seating right, then your calipers will not fit right. Are you trying a conversion of some type?
