Author Topic: 1of1 Refresh  (Read 2333 times)
Offline 1of1
1of1 Refresh
« on: April 23, 2012 - 08:04:22 PM »
After sitting for 10 years at shows and trailers , the soft goods needed help, so here are some pics of progress of interior....engine bay after refresh, I am picky , so tell me if you see something thats not correct........ :smokin:
1970 Cuda 383/335hp/4sp/V02
2006 FordGT40 Black Naked
Offline mojavered
  • Someday!
Re: 1of1 Refresh
« Reply #1 on: April 23, 2012 - 08:27:12 PM »
Not sure on the specifics with the details, looks perfect to me!  Keep us in the loop!
Jason
Offline 1of1
Re: 1of1 Refresh
« Reply #2 on: April 23, 2012 - 10:28:49 PM »
Because alot of you know the correct equiptmant for every year , I was looking for input on making sure I had the correct parts and finish on the car for the year. I will post final pics of the engine and interior for imput from the experts here!
Offline EB3-GranCoupe
  • BP23 U0B
Re: 1of1 Refresh
« Reply #3 on: April 24, 2012 - 12:43:15 PM »
Another B5 interior!  cool!!  what else are you going to be doing to your car?
Offline ragtopdodge
Re: 1of1 Refresh
« Reply #4 on: April 24, 2012 - 01:14:08 PM »
Awesome job!  Looks all great!
I THINK plug wires should be black.  I know it's factory correct for many cars, but not a huge fan of a lot of seam sealer on the firewall, but your's looks like a lot of cars I've seen.
Also, a minor not, easily fixed is I'm pretty sure the end of the neg. battery cable near the block is painted w/the engine paint.  Maybe up to about 2-3" up the cable.
Just needs a pie pan for the air cleaner and you're pretty much set.
« Last Edit: April 24, 2012 - 01:15:40 PM by ragtopchally »
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline 1of1
Re: 1of1 Refresh
« Reply #5 on: April 25, 2012 - 11:06:41 AM »
Do you know  if the reproduction correct spark plug wires will work ok with an updated electronic distributer....I was going to replace them but was not sure? Was the seam sealer you see what they did at the factory or is it wrong? :clueless:
Doing front end ball joints and left upper drivers side A arm, the one that is in it was bent when they intalled the bushings and the dummy installed it anyway and just a general refresh where ever she needs it........ I will start a link in the resto section and post progress....
Thanks Guys!
Offline ragtopdodge
Re: 1of1 Refresh
« Reply #6 on: April 25, 2012 - 12:10:45 PM »
As far as seam sealer, I've seen in many ways.  My preference (which may not be all that correct) is to have it completely removed from the outside and only put seam sealer on the inside, hidden, but I think it just depends who was working at the factory floor that day how much he used on any given car.
Yes, the new repop, date/part# coded spark plug wires should work just fine with electronic ignition.
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline ragtopdodge
Re: 1of1 Refresh
« Reply #7 on: April 25, 2012 - 12:12:31 PM »
Oh, I may be wrong, but I don't think the dipstick tube was painted???
Someone can correct me.  If true, then I would just remove the paint and clear coat it.
Probably the guy to as all this stuff is RestoRick (do a google search).  I think it's just www.restorick.com
06 300c SRT8
04 2500 QCLB 4x4 HO
  • BP23 U0B
Re: 1of1 Refresh
« Reply #8 on: April 25, 2012 - 12:25:56 PM »
i believe the dipstick is painted, tube and handle.
Offline 1of1
Re: 1of1 Refresh
« Reply #9 on: April 25, 2012 - 12:45:40 PM »
Thanks for the help!
Offline ragtopdodge
Re: 1of1 Refresh
« Reply #10 on: April 25, 2012 - 01:40:19 PM »
Here's some firewall shots of an OEM, reference restoration car.  Seam sealer poking through; again, it varies so you should be fine.
Yup, you're right.  Painted dipstick.
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline ragtopdodge
Re: 1of1 Refresh
« Reply #11 on: April 25, 2012 - 01:44:56 PM »
I'm not entirely sure, but perhaps the air cleaner is a bit too shiny???
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline 1of1
Re: 1of1 Refresh
« Reply #12 on: April 25, 2012 - 01:54:02 PM »
yes , most I see are wrinkle finish , but the stock stickers don't stay on, I think it should have been painted satin finish?, what year is the car in the picks......
Offline ragtopdodge
Re: 1of1 Refresh
« Reply #13 on: April 25, 2012 - 02:34:32 PM »
1970 Challenger.  A bit diff w/all the AC stuff, but rest should be the same as non-AC.
06 300c SRT8
04 2500 QCLB 4x4 HO
