Author Topic: distributor cap questions  (Read 3162 times)
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« on: April 25, 2012 - 03:33:59 AM »
So what is the best distributor cap to use, A B or C?  And does it make a difference?
A.  aluminum contacts inside
B.  brass contacts inside
C.  copper contacts inside
And why do the newer caps have the extra button on top?  The old caps had just 8 plain old towers.
newer
old school
« Last Edit: June 13, 2012 - 04:08:41 AM by hooD »
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline 72cudamaan
Re: distributor cap questions
« Reply #1 on: April 25, 2012 - 08:14:37 AM »
Larry, you want a cap with brass contacts. The aluminum contacts corrode very easily and are junk.
The extra "button" is actually a vent. Fine to use if you're not needing original look.
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #2 on: April 26, 2012 - 11:05:34 AM »
Copper , brass , alum from best to worst
 the vent releases ozone
« Reply #3 on: April 26, 2012 - 12:00:01 PM »
For your car Larry, I'd use the MP one even though it has the vent.  It looks more correct then a black one.
« Reply #4 on: April 26, 2012 - 06:03:50 PM »
Who sells caps with copper tower contacts. I've never seen one. Dealer caps are all Aluminium.  :dunno:
Offline hooD
  • detroit iron
« Reply #5 on: May 30, 2012 - 03:21:58 AM »
Scott....Autozone does.  part number CR2200G Copper towers with a brass center for the rotor.  $24
-Larry
1973 'CUDA 340
original owner
37,117 miles
« Reply #6 on: May 30, 2012 - 09:43:53 AM »
 :2thumbs:
Thanks Larry, I'll have to look up an Autozone this weekend when I'm down in Minneapolis for the car show.
Offline hooD
  • detroit iron
« Reply #7 on: June 07, 2012 - 03:34:22 AM »
installed the new copper cap and rotor.  the difference is obvious.
-Larry
1973 'CUDA 340
original owner
37,117 miles
