Author Topic: 5.7 Starting problem  (Read 877 times)
Offline 06Daytona
« on: April 25, 2012 - 11:32:01 AM »
The problem is on my 06 Daytona. I don't drive it much, other than playing musical cars and to get the dust off the tires. It's always started and run fine, but a few days ago I tried to fire it up for it's weekly move and it cranks but doesn't fire. I added Sta-bil to the fuel and keep it hooked to a battery tender to keep the charge up. I shot a little starting fluid into the air box and it fires but dies once the fluid is gone. I've turned the key to on and let it sit for a few seconds and it still won't fire. I've hooked it up to my code reader and the only code I get is wrong oil, but it's been like that since I brought it to Puerto Rico. My first thought is dead fuel pump, but I don't want to change that if I don't have to. Is there a way to test fuel pressure at home? If it was the Challenger I'd just unhook a fuel line, or look in the glass filter. Is it possible to disconnect the fuel line from the rail and crank it to see if there's pressure? I added some fresh fuel and a bottle of injector cleaner today just in case the fuel had gone bad or the injectors were gummed up, but it still didn't fire.
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
Re: 5.7 Starting problem
« Reply #1 on: April 25, 2012 - 04:07:46 PM »
I have no suggestions, but a dearly departed fuel pump is my first thought too. Since you are using Stabil in the gas tank, you should be good to go.
« Reply #2 on: April 25, 2012 - 11:07:10 PM »
there should be a pressure bleed on the injector rails , just like a tire valve , if you have pressure fuel should spray out when the valve is depressed
