Author Topic: exhaust  (Read 2558 times)
Offline rattlesnake
  • Rattlesnake
exhaust
« on: April 27, 2012 - 01:18:26 AM »
I am installing the rebuilt 440 back in my 70 Cuda.  I have alwaya had full 2" headers with 3 1/2 " collectors all along, but never really like the look.  Besides the finish not having long term durability, I have also had problems with clearance between the header and the steering shaft.  I don't want to lose performance or inhibit breathing but really want something besides the full size header, any suggestions?
Ray,
keep honking I'm reloading
Offline 72cudamaan
Re: exhaust
« Reply #1 on: April 27, 2012 - 08:16:33 AM »
Depends on the build. Not many motors need 2" tubes. If you're engine is
built for high hp then large exhaust comes with the territory.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline PlumCraZRT
Re: exhaust
« Reply #2 on: April 27, 2012 - 01:44:13 PM »
I agree with this.  If you want more clearance, go with a 1 7/8" system from TTI.
If you have a really mild/stock motor, consider the 1 3/4" system as well.
« Last Edit: April 27, 2012 - 01:46:12 PM by PlumCraZRT »
mmmmm.... Mopar.... *drool*
Re: exhaust
« Reply #3 on: April 27, 2012 - 02:40:03 PM »
Unless you have a radical build on the engine, there is no reason to have 2" headers.
I have 1 3/4" headers and 3" collectors on my car with a 440.
Re: exhaust
« Reply #4 on: April 27, 2012 - 03:13:23 PM »
I think there have been articles that show you accually lose hp with 2" primary headers on almost everything but a full on race engine.  Even if you did lose a few hp, I doubt you'd feel it on the street.
Offline PlumCraZRT
Re: exhaust
« Reply #5 on: April 29, 2012 - 01:43:08 AM »
You will lose torque (power = torque x rpm) because the exhaust velocity will be much lower in the 2" primaries.  When you're in the neighborhood, the trade becomes high-end power vs low-end torque.  The smaller pipe will favor low-end torque,  whereas the larger diameter will let it "breath" at WOT.
Offline rattlesnake
  • Rattlesnake
Re: exhaust
« Reply #6 on: May 01, 2012 - 11:31:06 AM »
O.K. I did not do a very good job of getting my question out there.  I do not like the headers.  What sort of factory or aftermarket exhaust is available that will not hog the engine compartment but still provide good breathing for a 500HP 440.
Offline 72cudamaan
Re: exhaust
« Reply #7 on: May 01, 2012 - 01:02:10 PM »
Outside of having a set of hp manifolds extrude honed, I don't think you many other choices.
No sense in putting bigger pipes on if the restriction is already at the manifolds.  :2cents:
« Last Edit: May 01, 2012 - 05:11:24 PM by 72cudamaan »
Offline rattlesnake
  • Rattlesnake
Re: exhaust
« Reply #8 on: May 01, 2012 - 02:24:12 PM »
I am familiar with the HP manifolds but the extrude hones lost me.  Are these something different than the regular HP manifolds?  Where can I get these items?
Ray
Re: exhaust
« Reply #9 on: May 01, 2012 - 02:27:42 PM »
ported oem hp exhaust manifolds.  I don't think you could get a max wedge manifold to work on 1 side either, not sure
Re: exhaust
« Reply #10 on: May 01, 2012 - 02:39:53 PM »
Extrude honing is expensive and the hp gain is almost nothing.  If you want to use manifolds your going to be down on power.  You can buy a different set of headers that fit nicer like Tri-Y's.  They don't make as much hp as more traditional headers but you wouldn't have as much of a loss.
  http://www.engine-swaps.com/Pages/ProductsType/BRB_Headers.html
