Author Topic: tach don't work?  (Read 1493 times)
Offline sleepie74
tach don't work?
« on: April 27, 2012 - 09:11:40 AM »
my tach is not working--can anyone tell me the steps to check it out?  thanks for any help    pat
Re: tach don't work?
« Reply #1 on: April 27, 2012 - 02:32:45 PM »
It's more than likely in need of being rebuilt as the originals didn't have a long life.
It gets it's signal from a gray wire on the "-" side of the ignition coil. Is that wire connected at both ends? It's connected to a tab on back of the tach. There is a blue wire that provides the power. Is that connected? The boot slips over the longest bolt on the back of the tach.
If you have the tach out of the dash, you can conduct your own experiment under the engine hood. You can run a wire from the "+" of your battery to provide power. You can run another wire from the "-" side of the coil to the tach. Then lastly, it has to be grounded. In the dash, it's grounded to the dash frame, but here you need to run a wire from one of the nuts on the back of the tach to either the "-" side of the battery, or a valve cover bolt, or anyplace you can get a ground.
Offline burdar
« Reply #2 on: April 27, 2012 - 05:04:44 PM »
Yep, factory tachs often go bad and are notoriously inaccurate.
Offline LAA66
« Reply #3 on: April 27, 2012 - 10:57:28 PM »
 Excellent response! :thumbsup:
 R/T Engineering has a rebuild kit which is affordable and pretty easy to install.
Offline Giveitawack
    • ebay
« Reply #4 on: April 27, 2012 - 11:40:47 PM »
Yepp. Worked fine for me.
Offline mopar397
« Reply #5 on: May 01, 2012 - 12:24:51 PM »
R/T Engineering?? where is that and they have a website?
Offline 4Cruizn
  • HEMI FISH
« Reply #6 on: May 01, 2012 - 12:38:51 PM »
I was just about to ask the same question . . . good timing!  Got the hardtop out and the tach didn't work??  Worked last year.  Then about 1/2 hour into the ride . . . waa laa . . .  it started working.  Turned the car off and started it up again and no tach.  Have to assume a loose wire.  Now I know where to look!   :2thumbs:
Offline 73Chally
« Reply #7 on: May 01, 2012 - 02:36:59 PM »
RT-Eng is now Dash Worx.  Try calling first, though, because he is always swamped.  There are other options like Redline Gauges, Instrument something or other.  Just do a Google search.
Offline sleepie74
« Reply #8 on: May 02, 2012 - 06:13:35 PM »
thanks danger field---will check what you said--thanks again--pat
