SURVIVOR vs. GROUND-UP RESTORATION!
Author Topic: SURVIVOR vs. GROUND-UP RESTORATION!  (Read 189821 times)
Offline hemiken
Re: SURVIVOR vs. GROUND-UP RESTORATION!
« Reply #450 on: November 10, 2013 - 07:20:28 PM »
Old cameras do have the shutter speed to freeze that action, but old film was frequently not fast enough to let the camera use those shutter speeds, especially if the image was meant for print.  :bigsmile:
So even if the negatives were available, would todays technology be able to freeze frame better quality or is it the negatives that is the problem :2thumbs:
Offline ChallengerHK
  • Moderator
« Reply #451 on: November 10, 2013 - 10:59:37 PM »
Don't want to steal the ECS thread, but the negatives (technically the originals, because most print-bound items were shot on positive film) would have captured what they captured. You can use digital technology to pull out a little more detail, and then you hit a wall.
- Han Solo, Star Wars
« Reply #452 on: November 10, 2013 - 11:06:20 PM »
Here are a few detail comparisons between an Original Chrysler Battery versus a Reproduction Unit.
Weren't the original battery casings made out of bakelite?
That would be a different durometer and porosity which would be the differences between the two.
Offline resq302
« Reply #453 on: November 11, 2013 - 07:38:47 AM »
I thought the original casings were made of a hard rubberized type of material which would have given it that exact finish as it more than likely was a rubber/plastic pebble that was heated up and melted/formed into place.  That would also explain the rough texture if all of the rubber/plastic did not totally melt.
Offline hemiken
« Reply #454 on: November 11, 2013 - 07:45:17 AM »
Thanks HK, i am sure Dave would not mind, you have enlightened us all :wave: Thank you. :bigsmile:
Offline resq302
« Reply #455 on: November 18, 2013 - 02:11:20 AM »
Ah, thanks for the correction Dave!   :2thumbs:
Offline hemiken
« Reply #456 on: November 18, 2013 - 02:33:05 AM »
The Factory units were a very hard (brittle) composite. They were constructed of a variant form of plastic that would chip or crack rather easily.
Hey Dave :wave: was it anything like bakerlite :dunno: or not that hard, as bakerlite is very brittle and sounds a lot like what your explaining :2thumbs:
Offline hemiken
« Reply #457 on: November 18, 2013 - 02:55:19 AM »
Bakelite is a synthetic plastic that is very hard.  The Battery cases were a polypropylene composite that is similar to the body of a ported vacuum switch.
http://www.ebay.com/itm/NEW-1968-74-PONTIAC-OEM-INTAKE-PORTED-VACUUM-SWITCH-6-PORTS-GM-3016754-/350595169968?pt=Vintage_Car_Truck_Parts_Accessories&fits=Make%3APontiac&hash=item51a119beb0&vxp=mtr
Yeah i know what your saying now, so it is just a HDPE item, i got you exactly now :2thumbs:
Offline hemiken
« Reply #458 on: November 19, 2013 - 07:02:35 AM »
HDPE refers to polyethylene; not polypropylene.  I'm pretty sure the Battery cases were made from a polypropylene composite.  :thumbsup:
• Polyethylene has a lower melting point compared to the higher melting point of polypropylene.
• Polypropylene is stiffer and resistant to chemicals and organic solvents compared to polyethylene.
• Polypropylene is pure, non-stretching and generally more rigid than polyethylene.
Yes yes yes, the old properties differences of Polyethylene as compared to Polypropylene :grinyes: thanks  :2thumbs:
Offline anlauto
« Reply #459 on: November 21, 2013 - 05:16:58 PM »
Does coating bare steel items with your product RPM classify as changing an aspect of how the car came from the factory ? :dunno:
Your product preserves the natural steel items which would not have been protected from the factory.
Your restorations duplicate obiviously the time of day the car rolled off the assembly line, but assembly line cars wouldn't have stayed that way very long.
By doing so, have your cars been "modified" in such a way to preserve the "fresh restoration" look ?
Just think of what classic cars would be if your product was added to all steel parts 40+ years ago.... :worshippy
Offline resq302
« Reply #460 on: November 21, 2013 - 07:34:00 PM »
Honestly, I would rather apply RPM over a part than paint it as painting would cover up the natural tones / varying colors of what a natural cast or stamped metal part would have.
Offline anlauto
« Reply #461 on: November 21, 2013 - 07:41:00 PM »
I have never laid eyes on a part that has been treated with RPM.  I can, however, understand how it can be 100% undetectable.
Having never tried it, I have to wonder if painting a bare cast part like a spindle with a properly shaded (flat/satin/gloss) clear coat can achieve the same "invisible" effect ?
I don't travel with the "OE" crowd, so a lot of this is pure curiousity.
Offline resq302
« Reply #462 on: November 21, 2013 - 07:45:17 PM »
Alan,
I have tried to copy the color of the metal color with paint and due to the texture, casting, machining, etc, you will never match it.  I have found with using the RPM, you can get almost the same sheen and color with using the RPM.  Im sure if I had polished or buffed the RPM a little more, I could have achieved the same sheen as what the part would have had originally.  Personally, I love the RPM product!  I have also put it to my own test with clamping treated and non treated parts on the front of my truck during the harsh salt ridden winters we have here in NJ and it has held up just like the independent tests have shown.
Offline anlauto
« Reply #463 on: November 21, 2013 - 07:47:59 PM »
I was actually asking about clear coat over bare steel, not paint to look like steel.
Offline resq302
« Reply #464 on: November 21, 2013 - 07:52:49 PM »
Alan,
I have tried clear coat over bare, untreated steel and it eventually will start to rust under the clear coat.  I tried that with the drive shaft on my charger and other parts inside the engine compartment on my Dad's old el camino and no matter what we tried, the rust always tended to start under the  clear coat and then ( I assume) eventually break through the clear coat.
