Author Topic: AAR Hood latch, spring front of hood  (Read 2006 times)
Offline AZDAN
« on: April 29, 2012 - 01:33:46 AM »
Did the AAR cars with the fiberglass hood use the pop up spring as the steel hoods? was it the same spring if they used one? What about the second release lever and hood latch were those used or just the hood pins. If the hoods used the latch, how was the the U shaped bracket attached to the hood?  just screwed into the fiberglass with self tapping screw  or were there inserts installed in the fiberglass?  Any pictures of the latches and brackets mounting to the front of the hood if they were used would be much appreciated.
Offline cwestra
Re: AAR Hood latch, spring front of hood
« Reply #1 on: April 29, 2012 - 08:54:08 AM »
They just had hood pins.  No spring and secondary latch.  Here is how it looked.
Corey - in Northern Indiana
Offline mikeljAAR
« Reply #2 on: April 29, 2012 - 01:00:47 PM »
That's correct, no latch, no spring, and be VERY careful about how you lift the hood after taking the hood pins out.   :smokin:
"I don't always downshift, but when I do it is near a Prius so they can hear me hurting the environment"
Offline AZDAN
« Reply #3 on: April 29, 2012 - 05:58:24 PM »
Thank you
Offline grimmey71
« Reply #4 on: October 11, 2012 - 08:46:10 PM »
I love this site, every time I google needing an answer it sends me right back here
Offline AARuFAST
  • AARuFAST
« Reply #5 on: October 11, 2012 - 11:14:23 PM »
I can't locate the picture on how to open the AAR hood.
The  correct way is to reach into the air scoop, grab the end corner and lift and with the other hand grab hold of the front of the hood to open.
Never grab the top of the scoop or the center of the bottom of the scoop.
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline grimmey71
« Reply #6 on: October 12, 2012 - 09:17:39 AM »
http://youtu.be/S6ucwys-pGs
More good info thanks! Makes me so glad I was lazy and didn't fill the scoop hole with screen mesh!
