Author Topic: First Drive!! Good and bad news  (Read 2740 times)
Offline NCtrueconservative
« on: May 02, 2012 - 11:21:55 PM »
First a little backstory on my 73 chally.  Earlier this week I had taken it up my road which isn't far, and I had turned up a little driveway (just a hair up hill) to turn around and the car died.  I could start it up but had to keep pressing the gas to keep it running. It would not idle.  Next day I adjusted the idle on it (eddy 650) a little bit and thought I had it. Took it up the road and turned left onto the main road which is uphill and it had nothing.  Died in a few feet and pulled the same stunt.  Even when I had it running, it would backfire ever so often.  I adjusted the distributor cap and got it runnin a little better, but figure I better give my cousin's boyfriend a call who is a mechanic and I swear can fix anything.  He came over tonight and got the timing pretty close and it was running good.  He noticed that when the mechanic put the motor in he didn't put a fuel filter on, and the right side of the carb was clogged with debris, so we fixed that and put down fuel filter on my list to do.  Got it running pretty dang good and took it up the road, now nighttime for its first official drive. I turned left onto the main road I had a few days before and it ran real good.  Took it up a hill, down a hill, some flat, followed by another hill, had it up to around 50, and it ran like a scolded dog. I was pleased!  :jumping: Then I turned into a church parking lot (who was letting out of wed. night service haha. Didn't mean to disturb em!) and the parking lot was a steep road and the car died and pulled the same stunt it had before. Wouldn't run unless on the gas.  So we were tinkering on it out there as people were driving away from church and I did get my first compliment! Two good ole boy rednecks (which we all are in this part of NC  :icon16:) pulled up in a dodge truck. They said "man thats a beautiful car. Is that a 2 or 4 barrel? What size motor it got in it?  Oh thats a stout motor...well she sure is beautiful."  Answered their questions and told em I appreciated it.  Limped the car home and my cousins bf noticed that the carb was not squirting ANY gas unless I was pressing the pedal.  Also noticed that the motor was extemely hot, sounded like the water was boiling.  But it wasn't shooting out the radiator and hadn't built up pressure but man it was roasting! He noticed the clutch fan had a bad clutch, so it wasn't turning fast enough, so thats ANOTHER thing I gotta do. Even though it seemed to me that it still shouldn't have got that hot during that little time, even with a slow fan.  He also recommended putting in at least a 160 thermostat. Told me he thought it was probably some gunk in the carb, either from setting or that ethanol gas. It was like it was sticking in there and just wasn't getting any gas.  I plan on taking the top of the carb off and cleaning the bowls real good and checking for anything, and replacing the clutch fan, seeing about a thermostat. Add that onto taking the old window and regulator out of the passenger side (which I have taken apart and put back in 3 times), taking it to get aligned, and taking it to get my gaps better, and get my windshield wipers working, and the list goes on!!! Still, that time I was ripping down the road was worth it!! Just something every minute with em, and just when you're close, they bite ya. Been busting a$$ with college and two jobs and working on the car in my spare time. Thats the name of the game though, hope a good carb cleaning is all it needs. Opinions and comments would be helpful!
1973 Dodge Challenger Rallye (pictured), 340, Slap Stick
1998 Dodge Ram, 5.2, Black, tinted windows, dual exhaust, blackout headlights, tailights
Offline GranCuda1970
Re: First Drive!! Good and bad news
« Reply #1 on: May 03, 2012 - 12:05:29 AM »
Workin through it. Looks like you got a pretty good handle of the situation and the publicity you are bringing to the hobby out on the street will net new mopar fans. Bet the two boys in the truck were surfing craigslist, ebay adds when they got home looking for one to buy.
« Reply #2 on: May 03, 2012 - 12:09:10 AM »
haha they had a 94-01 dodge ram crew cab, v8 with exhaust that came out the side in front of the bed and went into stacks on the side that went all the way to the roof. Beat all I've ever seen!
« Reply #3 on: May 03, 2012 - 12:14:46 AM »
Sounds good I may need to eventually hunt up a regulator for the drivers side door myself. The prev owners ran it so long out of adjustment that it was wearing hard into the sprocket teeth. Fits good now that it is adjusted but a little loose in the middle of the roll-up.
Offline AARuFAST
  • AARuFAST
« Reply #4 on: May 03, 2012 - 08:32:35 PM »
To see if your clutch fan is working correctly.
With motor off....... spin the fan with your hand.
If it spins more than 1 1/4  turns it should be replaced.
It should not spin easily.
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
« Reply #5 on: May 03, 2012 - 09:33:57 PM »
Was it these two guys? :roflsmiley:
My 1st HEMI ad
« Reply #6 on: May 03, 2012 - 09:39:26 PM »
Haha something about like em Brad! And yeah its way too easy to turn. Still would the motor get to the point of boiling water after 3 minutes of driving down the road? And anyone had issues withthe carb like Im having? Seem like a sensible solution?
Offline msbaugh
« Reply #7 on: May 03, 2012 - 10:32:12 PM »
I've been having similar issues. I started mine the other day and it ran for about 5 minutes then kept dying like it was starving for fuel. After it died it wouldn't idle for sh**! It worried me because I had just put 5/8 fuel lines, a new pick up, mechanical pump, fuel regulator, and 750 Holley dp on it. Thinking some thing was wrong. So I pulled the sights off to check fuel level in the bowls and my front bowl was bone dry, which explain why there was no fuel squirting from front. The rear was fine though which puzzled me. I'd check to see if the needle is stuck, sometimes an easy fix is to get the handle of a screw driver and tap on the adjustment nut, sometimes that will un-stick it. Lol.
« Reply #8 on: May 03, 2012 - 10:48:54 PM »
yeah thats what my mechanic friend thought that it was stuck in there. Mine was the same way. Didn't have a bit of gas when idling, only when I hit the gas.
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #9 on: May 03, 2012 - 11:45:10 PM »
I never did like the Edlebrock carbs. They always seemed to have a stumble or bog issue that I could never get to go away, but other people love them. I went with a Holley performance carb and had no issues. I would definitely look at my float levels and make sure they are adjusted right along with your primary and secondary butterflies. Make sure you have good fuel pressure. And a good filter that isn't clogged. I once had a defective Holley carb brand new out of the box that had a leaky float on the front bowl and caused all kinds of trouble. You might want to look at your accelerator pump and make sure it's not bad. It won't squirt good with a bad accelerator pump!!  :2thumbs:
        Matt B.
Matt
« Reply #10 on: May 03, 2012 - 11:48:23 PM »
Im gonna try to take the top off the carb tomorrow and see whats going on. And I tell ya, with my luck, it wouldn't matter if I bought an Eddy, Holley, or a million dollar carb job, I would have the lemon of the bunch!!  :banghead:
« Reply #11 on: May 04, 2012 - 02:50:20 AM »
2 steps forward one step back but you'll get there eventually. :bigshades:
Offline msbaugh
« Reply #12 on: May 04, 2012 - 12:21:25 PM »
I've also had similar issues caused by vapor lock. Do you have a return line? I opted out of a return on mine so I could run a mechanical pump with a non-return regulator. Looking at your fuel pressure can give you a good starting point as well
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #13 on: May 04, 2012 - 06:45:19 PM »
Check your float levels.Tha accelerator pump will only "squirt" gas when you first hit the throttle  and will not do anything while the engine is just idling if that is what you were referring to.A back fire is also a condition of the engine going lean=no fuel.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline johannes
« Reply #14 on: May 04, 2012 - 08:02:14 PM »
Possible corrosion in fuel tank ?...clogging the "in tank coarse filter" and possibly messing with the valve function in the fuel pump?
...or simply a faulty fuel pump ?
Any difference in engine handling having full tank vesus almost empty tank ?
