Author Topic: Cleaning Old Never used plug wires.  (Read 884 times)
Offline GranCuda1970
« on: May 03, 2012 - 12:39:06 AM »
Bought these years ago just pulled em out of the bag. They surpossedly were origional sparkplug wires from ages old. Well upon closer inspection noticed the brass is alittle oxidized and there seems to be a little build-up in the plug connector. Should I stick a bore brush in there to clean it out or is there some kind of solution I can soak the end in to clean the connection without damaging, (the seems to be brass). I would really like to use the origional wires. Sorry cruddy pics and focus not so good on close in shots.
Re: Cleaning Old Never used plug wires.
« Reply #1 on: May 03, 2012 - 08:38:18 AM »
White vinegar should clean that right up.  Make sure to use some dielectric grease when you install them.
« Reply #2 on: May 03, 2012 - 09:17:43 AM »
Thanks for the quick response Burdar!!
Offline michelclarke234
  • Newbie
« Reply #3 on: February 20, 2013 - 12:08:37 PM »
Bought these years ago just pulled em out of the bag. They surpossedly were origional sparkplug wires from ages old. Well upon closer inspection noticed the brass is alittle oxidized and there seems to be a little build-up in the plug connector. Should I stick a bore brush in there to clean it out or is there some kind of solution I can soak move out cleaning the end in to clean the connection without damaging, (the seems to be brass). I would really like to use the origional wires. Sorry cruddy pics and focus not so good on close in shots.
I always used of lubricants like kerosene and petrol to clean these parts..
« Last Edit: February 21, 2013 - 12:37:06 AM by michelclarke234 »
Offline 72cudamaan
« Reply #4 on: February 20, 2013 - 12:23:57 PM »
Burdar is right on the money. Dielectric grease does wonders.
If I cant fix it, it's broke
Andy  (phukker whither)
