Been a bit slow on updates.
Got vinyl top glued down on Thur. Paid an experienced pro to do the job. WOW, money well spent. The 2 pages of instructions that came with the top will only get you started. There is alot no written down. Looks fantastic. Pro work hard and fast for 2 hrs. F38 ados glue in a pressure pot, heat gun running , and sissors for al sorts of jobs.
Got the heater in. Put couple of bits in engine bay, including wiper motor. Used some heat shrink tube to replace the fabric sleeves on the wiring.
Painted the hood lining metal trim. 1 coat of etch blk and 3 coats of satin blk.
Got header unit back with 2 new lugs. Got last coat of primer on it. Sand smooth , then off to painter.
Engine builder has ha block and heads in hot tank for few days. Pulled heads out and they look great. Real virgin ones. Ordered some Isky springs, retainers, and valve seals. Pushrods later. Are going to go with roller rockers as Lunati cam has .494 lift. Got some 440 source ones off a friend. Was a thread about someone who had issues with these. Builder said he will put small dab of tig on end of pin , and it will be fine.
Sump pan is not the standard e-body one but have measured it and it will fit. Needs some panelwork on sharp dent.
