727 to A518 swap – a novice guide
Author Topic: 727 to A518 swap – a novice guide  (Read 282305 times)
Offline 6PakFish
  • Move Over Power Approaching Rapidly!!!
Re: 727 to A518 swap – a novice guide
« Reply #225 on: November 29, 2017 - 10:32:52 PM »
Can anyone help me with my non lock up 46rh. I swapped over a couple years ago and this site was so helpful in getting it done. All has been going well until the over drive quit working on me. turned out it was a short in the wire inside the trans. While I has the valve body out to replace the over drive solenoid I put in a transpak shift kit. I got all back together and it all worked well and shifts were much better.
Well now there is a new issue. As stated before all was working well until the other day when the trans would lock up when manually shifted into first. I put the cuda up on the lift and shift in to first and the trans will not turn the tires When I shift to 2nd and 3rd trans works fine. when I put it in reverse it seems to drag a bit before the tires will turn.
By the way linkage is working fine and trans selector hits all detents.
So I drain trans and pull the valve body and the second gear accumulator drops out in three pieces. Well I think bingo. Its a plastic one that came in trans. Well I got my old 727 out and pulled the accumulator out of it and its a cast aluminum. Bonus right. Well I put it in and put it all back together again and I still have the same issues.
So what would cause these systems. Thanks.
Offline 1 Wild R/T
« Reply #226 on: November 30, 2017 - 10:01:43 AM »
Any chance you adjusted the front band & got it to tight?  Sounds like it's holding when it shouldn't be...
« Last Edit: November 30, 2017 - 08:26:38 PM by 1 Wild R/T »
Offline 6PakFish
« Reply #227 on: November 30, 2017 - 11:59:47 AM »
Any change you adjusted the front band & got it to tight?  Sounds like it's holding when it shouldn't be...
I have adjusted both bands with two different torque wrenches. Still binds in First. Thanks.
Offline DrEamer
Re: 727 to A518 swap � a novice guide
« Reply #228 on: July 25, 2018 - 12:36:20 AM »
Digging up this old thread again, it is pretty much a resource that keeps on giving. Anyway, I am considering doing this conversion myself, and found another way to control the overdrive and converter lock up points. It looks like Compushift makes a stand alone unit that controls both electronically. The plus side appears to be that it is not effected by low vacuum, plus the head unit can be mounted, and adjusted in the car. The one downside I see is if you have a carb, you need their TPS unit that adds to the cost. Link provided below.
 https://www.hgmelectronics.com/compushift-mini-for-chrysler-a518-46rh-and-a618-47rh/
Offline roadrunninMark
« Reply #229 on: July 29, 2018 - 06:58:48 PM »
That looks interesting, Doc.  I just emailed them to see if it can be used with a 42RH trans as well.  I will report back.
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
« Reply #230 on: July 30, 2018 - 10:56:10 AM »
Since the A500 and A518, are operated identically, then the controller would undoubtedly work for it as well.  This looks like it would be great, but would add another $500+ to the swap.
It would be better if they had a controller for the later/better 42/46/47 RE.  They are way more available and have all the durability updates the earlier RH's didn't have.  That would be the hot ticket.
« Last Edit: July 30, 2018 - 11:03:36 AM by PlumCrazyChris »
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
« Reply #231 on: July 31, 2018 - 03:55:13 PM »
Just confirmed that the electronic control will work with the 42RH as well.  We need a TPS system so that is about 130-170 more depending on what carb you have.
Chris, did you finish your trans mounts?
Offline GoodysGotaCuda
« Reply #232 on: July 31, 2018 - 04:38:37 PM »
Why is a tps $130-$170? I would think a 5v linear potentiometer would do it for pretty cheap.
Id like to do this swap on my small block Warlock.
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #233 on: July 31, 2018 - 05:30:52 PM »
Yes I've had it installed for 4 years now.  Works great.
PlumCrazyChris
Round Rock Tx
www.mopar.org
« Reply #234 on: August 01, 2018 - 06:24:31 PM »
Goody - That TPS is one that is a plug n play with their controller.  I guess if you are electronics savvy, you can make one cheaper.  If you already have one as your vehicle is fuel injected, then you are good to go.
Chris - Do you have plans available to make the mount?  Do you just cut it out from a piece of flat metal and bend it up to the correct shape?
« Last Edit: August 01, 2018 - 06:26:19 PM by roadrunninMark »
« Reply #235 on: August 14, 2018 - 04:44:27 PM »
Yes just cut it out of flat stock and bend it up, bolt it together and paint it.  I'd planned on cutting them out and selling them, but I haven't gotten the time to get it all taken care of.  I'll make more of an effort to finish it and get a cost for them.
Chris
PlumCrazyChris
Round Rock Tx
www.mopar.org
Offline pngkid
  • Newbie
« Reply #236 on: August 21, 2018 - 08:57:00 PM »
Been reading this guide for a year or so now. Got a 46RH non-lockup from a pick a part (3500 van) to put in a 300C behind the 392. Thanks for all the great information.
Chris
« Reply #237 on: June 24, 2021 - 12:30:26 PM »
So I've been running the A518 behind my 5.7 hemi for nearly 10 years now, but one thing has bothered me the whole time.  The LU on the torque converter stays locked when I take my foot off the gas causing engine braking....    Its not a huge thing, but is irritating.  Everything else works like factory.
I'm wondering if anyone else has figured out a way to unlock the LU when you take for foot off the gas so it free spins?   I would think some kind of TPS, or micro-switch on the pedal or linkage would work well, especially if your using a carb, but with my factory throttle, I haven't come up with an answer.  I am using the stock throttle pedal.
Anyone have any thoughts on how to unlock the LU?
PlumCrazyChris
Round Rock Tx
www.mopar.org
Offline jimynick
« Reply #238 on: June 24, 2021 - 11:34:35 PM »
Sorry, I can't help with the knowledge, but I'm interested in the concept and look forward to seeing where this goes. Good luck! :cheers:
Offline Aussie Challenger
« Reply #239 on: July 06, 2021 - 08:46:02 PM »
The whole idea of having a LU convertor is to effectively have a solid connection between the engine and output shaft of the transmission like you have on a manual or stick shift. It is dangerous to have a transmission "free wheeling' while mobile. Some kits have a vacuum control switch which will release the OD back to the standard "top gear" or 3rd if that is what you are looking for.
