Author Topic: Removed front and rear window revel moulding:No pins for revel clips found! Fix?  (Read 1536 times)
Offline DocMel
Just removed the front and rear window revel mouldings form my 71 E Body:  And found out the previuos owner had just calked the mouldings in place :eek7::   Not one revel clip or its mounting pin were found!
So...... :clueless:...........Since the body mounted revel pins  (the ones that were supposed to be on the car itself) are no longer there for the actual revel moulding clips to clip onto........
I understand there is a fix that looks almost like a self tapping screw that has the proper head that will snap onto the revel moulding clips..Anyone have a source that they could recommend?
If your car is painted already Roseville auto sells the screw in stud type that holds the clips.
If it's not painted yet, the right way is to use the stud gun welding rivet tool.
http://www.tcpglobal.com/autobodydepot/docs/hasstudwelders.pdf
There's one tip made exclusively to weld on the rivets that hold the clips.
Offline mopardave
  • Sponsor
    • rosevillemoparts
you can use any type of self tapping screw, doesnt need to have a shoulder. here is a pic of what comes in a kit
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline DocMel
Thanks guys   Pic was perfect   Car is painted, so Im going with the self tapping screws.  I have the clips, so easy day
Offline jackie
Dave, what are the two thing's at the bottom?  guides to drill the holes in the right place?
1970 challenger r/t, prostreet 438 ci. 4 speed
Offline mopardave
  • Sponsor
    • rosevillemoparts
the clip kit in the picture is for the rear window, the metal tabs are the spacers that screw to the deck filler to support the glass when installing.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline jackie
ok, thank's.. i have never seen the spacers. i have seen rubber blocks,that hold up the glass.
Hey Doc,
How bout a picture of your project.
Offline DocMel
Ok   Ill get a pic posted under another topic today
