Author Topic: Magnum Force Drop Spindles Wheel size help??  (Read 1474 times)
Offline Supersuter06
« on: May 08, 2012 - 05:40:10 AM »
Ok i just bought the magnum force 2" drop spindles i wanna run 17x8 inch torque thrust 2s in the front anyone know what back spacing/ tire size i should go with?? Also i have the hotchkis torsion bars and i saw people were complaining about the ride height being to low am i totally screwed?? I havent seen the ride height with them seeing as my 74 challenger is just a striped down body right now lol Hope someone can give me a good idea of what rims to buy before i take the leap.
Re: Magnum Force Drop Spindles Wheel size help??
« Reply #1 on: May 12, 2012 - 09:46:40 AM »
With a 17" rim, a 5" backspace is probably safe. Dig through some of the threads here. There is some good info on both 17" fitemnet and drop spindles.
Offline PlumCraZRT
« Reply #2 on: May 13, 2012 - 05:36:20 AM »
With 2" drop spindles, you may want to contact Hotchkis about returning them.  Maybe call and see if they will take them back after you install them (if need be) so you can try them.  Somebody mentioned he couldn't get the jack out from under the car (with what I assume were stock spindles) unless he had the adjusters all the way in.
mmmmm.... Mopar.... *drool*
Offline Doomed
  • So close...to actually finishing my 'Cuda!
« Reply #3 on: May 21, 2012 - 09:22:41 AM »
I have MF drop spindles with WW brakes and 17x8 TTII's on the front with 5.5 bs.
"Life gets in the way of Living"
Offline 72bluNblu
« Reply #4 on: May 22, 2012 - 07:31:23 PM »
I don't think you'll need the drop spindles with the Hotchkis torsion bars. Hotchkis was even refunding folks some money because the cars sat so low in the front using their torsion bars.
If you do keep the drop spindles, you'll want to watch out for tie rod interference. The drop spindle moves the tie rod back near the lip of the rim, instead of having it sit inside the rim like it usually would with a 17" rim. I have 17x9's with a 5" backspace on the front of my car with my MF drop spindles, it clears but its a little cozy. 17x8 would give you some more room, as Doomed pointed out with his 5.5" backspace.
