Author Topic: distributor drive gear 440  (Read 899 times)
Offline rattlesnake
  • Rattlesnake
« on: May 10, 2012 - 03:22:10 PM »
How do I time the distibutor drive gear on a 440 RB engine?  Which way does the slot point and when?
Ray
keep honking I'm reloading
Re: distributor drive gear 440
« Reply #1 on: May 10, 2012 - 07:48:55 PM »
The drive can be positioned anywhere by changing the position where the teeth mesh & the dist can mesh in 2 positions once the drive is in position . It really doesnt matter  where the rotor is pointed , if you are TDC #1 I generally point the rotor to the back that way 8 Sits along the valve cover & 4&6 are on the right side of the dist & only #3 & #@ have to cross over the dist cap
