Author Topic: Carb recommendations  (Read 6598 times)
Offline HP_Cuda
  • Mopar or No Car!
« on: May 11, 2012 - 02:49:16 PM »
I see alot of folks giving recommendations on carb sizes without knowing the science behind them.
What you need to know is Volumetric efficiency. Yes you can put a 800cfm dominator on a 318 small block but you will be very inefficient and will have paid for a carb that is overkill.
VE = (3456 x cfm / cid x rpm)
So just for fun I've built a chart for different Mopar engines with a max rpm of 6000:
Cubic Inches            Carb Size recommended
318                           600cfm (needed 555cfm for 100%)
340                           600cfm (needed 590cfm for 100%)
360                           650cfm (needed 625cfm for 100%)
400                           700cfm (needed 700cfm for 100%)
426                           750cfm (needed 750cfm for 100%)
440                           770-800cfm (needed 765cfm for 100%)
A good VE calculator is here if you want to play around and change the variables:
http://www.ajdesigner.com/phpengine/engine_equations_volumetric_efficiency.php
I'm partial to Holley carbs as I have rebuilt many of them and know the ins and outs of them.
B
Re: Carb recommendations
« Reply #1 on: May 11, 2012 - 08:11:21 PM »
The theory is good but it doesn't work ..... my 440 ran OK with an 850 DP holley on it 12.4 in the 1/4
I upgraded to a 950 Vacuum & dropped to 12.2 , so I installed a 1050 dominator & the car went 11.7 .
 the Factory used 850 TQ carbs on 360s no problem & the 950 6 pack on a 340 so either the carbs are overrated or the theory is flawed
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2 on: May 18, 2012 - 01:47:25 PM »
Tell me how you built your 440?
Offline 06Daytona
« Reply #3 on: May 18, 2012 - 02:05:17 PM »
I've seen a calculator like that somewhere that took into account cam specs, rear end, tire size and a few other variables that seemed to be pretty accurate. Using a 440 for and example the carb size was anywhere from 750 to 1200+ depending on boatloads of variables
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
Offline Road_Runner
« Reply #4 on: May 18, 2012 - 06:01:29 PM »
Mopar Performance recently did a carb comparison on their mildly built 383 test motor.  If I remember right the best carb was a non HP 850 double pumper.  Smaller than that, they gave up as much as 50 HP in their test.  I agree that for most street driving a smaller carb than may folks try to run on the road is better, but for 1/4 mile or top HP it appears bigger is better.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
