It can be done , not nessisarily easily, by leaving the rack at the rear & using stock spindles oyu will not mess up the steering angle , you will need a STRONG support yo hold the rack to the K frame though & the biggest consideration is having the inner tie rods close to the same width as the mounting points for teh lower control arms to minimize bump steer problems
