Author Topic: rear drum adjustment  (Read 957 times)
Offline barryv
« on: May 12, 2012 - 09:05:39 PM »
hi,can someone tell me which way  the star /teeth adjuster should go to adjust the brake shoes for a better pedal feel,thanks
Re: rear drum adjustment
« Reply #1 on: May 12, 2012 - 11:30:51 PM »
The picture is of the drivers side, from the outside viewpoint the teeth curve down and are engaged by the adjuster lever being pulled up turning the wheel clockwise to lengthen (viewpoint of the rear of the car). The passenger side is the mirror image so the wheel is turned counter-clockwise.
Using a brake spoon point the end up through the adjustment slot on either side and rotate down to lengthen the screw assembly to tighten the brakes, reverse to loosen.
I discovered you have to "cock" the adjuster lever to get it to engage the star wheel properly. I grabbed the lever with a pair of pliers & pulled straight down then released.
« Last Edit: May 12, 2012 - 11:35:57 PM by Bullitt- »
Offline TinCuda
    • 'Cuda
« Reply #2 on: May 13, 2012 - 12:43:52 AM »
 :popcorn:
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
Offline barryv
« Reply #3 on: May 13, 2012 - 01:52:25 PM »
thanks fo the reply. i adjuted rear brakes and pedal is better. it still needs  to  be re bled, bake  pedal goes to far to floor
