Author Topic: 8 3/4 rear sure grip with 323 ratio what`s it worth?  (Read 9943 times)
Offline Barracudadan
« on: May 13, 2012 - 07:17:58 PM »
I have the original /6 rear end in my cuda with a 318 and an automatic trans right now. I am upgrading the engine to a 360 with a mild cam in it. I may be able to get this rear end I mentioned in title of my post from a 72 cuda same as mine, but would like to know what is a fair price for it.
Also does anyone know what the ratio would be right now in my stock /6 rear end when I am cruising down the highway it just doesnt feel right it works fine just doesn`t "feel" right is the best way I can explain it. I would like something that would give me a nice cruising gear for the highway but yet still have some get up and go from a red light.
Offline Gumby
Re: 8 3/4 rear sure grip with 323 ratio what`s it worth?
« Reply #1 on: May 13, 2012 - 08:12:47 PM »
You will probably have to change axle shafts as well. Splines may be different. Most go for 3.55 or 3.91. You probably won't get full use out of those gears. 360 low compression smog motor won't net you much.
{oo/-------\oo} In '69 I was twenty-one and I called the road my own. I don't know when that road turned into the road I'm on. Jackson Browne
« Reply #2 on: May 13, 2012 - 08:31:09 PM »
For all around ratio most use either 3:23 or 3:55 depending on rear tire diameter. :2thumbs:
As for your original /6 gear ratio...? I have no idea? Jack up the rear end while in neutral, count how many times the tire rotates for one rotation of the drive shaft. Use chalk to mark the tire to make it easier to count.
You might need to change the speedometer gear to make it read right again if the ratio is different. Not a big deal, or expencive, 20-30 bucks?
My car was a /6 originaly too . When I swapped in the 8 3/4 I have about $650 into it total with new wheel cylinders. I have 3:55 sure grip 489 case. Goes down the hwy at about 3000rpm's or so at 65 mph.  You will also need a different lenght driveshaft. I scored one for $100 from Kijiji
Use these links to figure things out.
http://vexer.com/automotive-tools/speed-rpm-calculator
This chart is for selecting the correct speedo gear
« Last Edit: May 13, 2012 - 08:33:09 PM by brads70 »
« Reply #3 on: May 13, 2012 - 09:29:27 PM »
Thanks for the replys. I was thinking this would just be a farly simple swap of rear ends. I never thought about the driveshaft length. This rear end was from a 340 car that has a 440 in it now I wonder if the driveshaft is still there and if it will work. I have not seen it in person yet.
« Reply #4 on: May 14, 2012 - 04:11:03 AM »
It depends on what transmission both cars have? A 727 uses a different length driveshaft than a 904.
A 440 can only bolt up to a 727, but a small block could have either a 727 or a 904.
Offline JayBee
« Reply #5 on: May 14, 2012 - 09:15:54 AM »
My 1970 318 originally had the /6 (7 1/4) rearend too and it's ratio was 2.76.
John
1970 Barracuda convertible
2014 Toyota Avalon
« Reply #6 on: May 14, 2012 - 10:09:34 AM »
I have a 904 will my driveshaft work? Or do I still need to find out what transmission is in parts car?
« Last Edit: May 14, 2012 - 10:17:16 AM by Barracudadan »
Offline ChallengerHK
« Reply #7 on: May 14, 2012 - 10:20:07 AM »
Look at the shape of the transmission pan and compare to this:
- Han Solo, Star Wars
« Reply #8 on: May 14, 2012 - 05:05:30 PM »
Well I can get the rear end and a complete power disc brake setup off this car he gave me a price over the phone of $600. I`m thinking this is a decent price.
So the transmission on the parts car should be a 727 and I have a 904 on my car which driveshaft will I need mine or the one off the 727 tranny?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #9 on: May 14, 2012 - 05:47:11 PM »
For $600 bucks grab it, normally the mopar sellers want that just for a posi 3.55 chunk...... :jumping:
« Reply #10 on: May 14, 2012 - 06:12:07 PM »
I don't think so? The 7 1/4 rear end is shorter than a 8 3/4 .
Actually I'm sure of it as the driveshaft from the 7 1/4 rear end it still sitting in the garage and it's too long for a 8 3/4 rear end
« Last Edit: May 14, 2012 - 06:42:30 PM by brads70 »
« Reply #11 on: May 14, 2012 - 11:01:41 PM »
 :clueless:  So if I am reading all this info correctly it`s possible that neither driveshaft will fit this swap i`m planning.  Leaving me these options get a 727 tranny and use driveshaft from parts car. or shorten my driveshaft off the 904 tranny to make it fit  :dunno:. I do appreciate all the help so far when it comes to some of this stuff i`m a total NOOB!
« Reply #12 on: May 14, 2012 - 11:18:17 PM »
Another option is get a driveshaft made, if you need a different length. It's actually not too expensive.
« Reply #13 on: May 14, 2012 - 11:26:18 PM »
True I could do that as well. I was just thinking too I have Doug`s headers and one of the notes was they will not work with a 727 trans so that option may not work for me unless I want to make more changes,which I don`t want to do. This rear end would be a project for over the winter so I got time to figure it all out.
Offline TinCuda
    • 'Cuda
« Reply #14 on: May 14, 2012 - 11:52:33 PM »
Believe me.   I know how frustrating this can all be.
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
