What Computer Managment system?
Author Topic: What Computer Managment system?  (Read 17844 times)
Offline ShelbyDogg
Re: What Computer Managment system?
« Reply #30 on: November 10, 2012 - 07:18:50 PM »
I saw an episode of Trucks or Muscle Car on spike TV. They ran a new Hemi with the ez-efi system on top and the MSD ignition controller for the spark. Started it up and started dyno pulls as soon as it warmed up!  If you don't need a computer to control your automatic trans or run a manual tranny, I would go for this setup. I have an EZ-EFI setup on my 440 Challenger now.
« Reply #31 on: November 11, 2012 - 08:13:15 AM »
Just learning here.... so what if you do need a computor to control your automatic?  I'm using a simple shift controler now.
Offline ShelbyDogg
« Reply #32 on: November 11, 2012 - 10:41:41 AM »
Probably have to stick with the stock compucter to run the engine and tranny then.
« Reply #33 on: November 11, 2012 - 11:51:11 AM »
Ah gotcha... your meaning the stock auto/modern Hemi set up. :2thumbs:
Offline challenger500
« Reply #34 on: November 12, 2012 - 08:17:02 PM »
Motec - pricey but top of the line
Dementia already from the year...mmmm ???
Offline KiwiChallenger
« Reply #35 on: November 28, 2012 - 03:02:43 AM »
These ECU's are made here in New Zealand and are a well made product. I have used a few for conversions but not for a hemi yet unfortunatly.
http://www.linkecu.com/products/engine-management-ecus/g4-xtreme
These ecu's are $2300 they do cheaper options starting at $1600. We have a lot of options for after market engine management down here, it is surprising to me how few options you guys have.
Offline Jousi
« Reply #36 on: November 30, 2012 - 12:22:40 AM »
For a 3G hemi swaps there are not so many options...
Majority of the aftermarket units can´t read hemi crank and cam sensor, this is the problem. Of course it is possible to add extra trigger wheel etc. to get everything running.
BH23G1B TX9 5.7 Hemi+5-speed
JH23J0B FC7 4-speed
BS23R0B TX9 auto
Offline Rolling_Thunder
  • only 2 things get my attention, gas and perfume
« Reply #37 on: December 10, 2012 - 01:39:41 AM »
I used an OEM PCM tuned by Squire...        Made my own engine harness as a stand alone unit.    :cooldancing:
2013 Dodge Challenger R/T - 5.7L / 6-speed
1973 Dodge Challenger Rallye - 340 / Auto
1968 Dodge Charger - 6.1L / 6-speed
1964 Dodge Polara - 440 8-71 / 4-speed
Offline grimmey71
« Reply #38 on: December 10, 2012 - 01:52:46 AM »
This is interesting, do you mind telling me how much this cost you. As of right now I still plan on buying a PCM from modern and probably the harness too but just curious.
« Reply #39 on: December 10, 2012 - 12:00:23 PM »
The PCM cost me $50.00 off Ebay - sent it to Squire and had it tuned for about $500 which includes a new Diablo InTune (looks like an iPhone) ---  Harness I scored for $100 and spent maybe $30 to modify it (heat shrink, solder, relays)  and a butt load of time.  but now it's second nature.
Offline grimmey71
« Reply #40 on: December 16, 2012 - 11:02:55 PM »
I have the full wiring harness out of my donor vehicle for my 6.1. I was hoping to do what you did but it seems a little over wheeling at times. So was it basically just cutting out the parts that will not be used?
« Reply #41 on: December 17, 2012 - 12:17:07 AM »
You can use the large fuse blocks and all that - the easiest way would be isolate the engine harness and part of the dash harness - then remove items not needed and replace the large fuse block with a relay pack and make it more of a stand alone harness.     I'll write up some stuff in my build thread on basic wiring for the 3G hemi
Offline Haddixj
« Reply #42 on: December 17, 2012 - 09:42:47 AM »
Sounds good. Did you find a pin out diagram for the engine harness?
« Reply #43 on: December 17, 2012 - 12:36:35 PM »
I have it somewhere but the problem is in the newer manuals the wiring pin out is something like 40-50 pages for the PCM - I am making a condensed list right now which is whats taking so long.
Offline JpRngr
« Reply #44 on: December 30, 2012 - 01:25:48 AM »
So did you ever get a chance to do a write up? If so, any links to it?
Corey
