surface rust treatment help
Author Topic: surface rust treatment help  (Read 1034 times)
Offline Jocigar
« on: May 16, 2012 - 09:35:01 AM »
Hi all,
I am pulling some of my suspension parts out of storage and they have some small areas with surface rust break through, they were blasted and then painted with seymour stainless steel pigment spray cans at the time.
Is there a local product, Ace/napa I can buy to treat the rust after I scotch bright the surface?  I don’t want to disassemble the units and start over with sandblasting.  Maybe denatured alcohol with a shot of rust inhibitive primer is fine?
Thanks
Offline jackie
Re: surface rust treatment help
« Reply #1 on: May 16, 2012 - 10:25:59 AM »
not sure what pieces you have,  but por-15 on the rust is great stuff. just blasting and rattle can paint, it will all rust back in time. i would por-15 the rust, sand and spray epoxy primer and then paint it.
1970 challenger r/t, prostreet 438 ci. 4 speed
« Reply #2 on: May 16, 2012 - 12:30:37 PM »
I would recommend Rust Bullet.
I've heard people complain about POR-15 adhesion issues before.
Offline jackie
« Reply #3 on: May 16, 2012 - 01:06:00 PM »
it only sticks to rust.(well, and your skin).
Offline Jocigar
« Reply #4 on: May 16, 2012 - 01:45:58 PM »
I remember reading about evapo-rust and metal-etch I think both from local retail stores?... I should have satin clear coated the parts.  Thx
Offline Jamiez
  • Retro
« Reply #5 on: May 16, 2012 - 04:30:10 PM »
evapo rust does strip rust off parts.  If you soak it, brush/rinse it off, let it sit for an hour or two and then soak it again, the part will get a dull finish on it and will rust very slowly.  I typically either RPM the part if it's staying bare, or paint it when it's in that state,
Offline ChallengerHK
« Reply #6 on: May 16, 2012 - 06:47:57 PM »
POR sells some prep spray that has to be used in order to get good adhesion. If you don't use it, the stuff comes off in sheets.
- Han Solo, Star Wars
« Reply #7 on: May 16, 2012 - 10:24:22 PM »
that I didn't know.
Rust Bullet, you can actually sand smooth pretty easy.
Reduce with Acetone or reducer and spray it on.
I sprayed the inside of my quarter panel with it before I put it on. Gave it a scuff with 80 grit, then epoxy primered. I bet it lasts 100 years if the car stays in CA.
« Reply #8 on: May 16, 2012 - 10:27:24 PM »
For small parts like some of the suspension parts; you can buy a Preval sprayer. hardware stores carry them quite often.
 Reduce it a little and then spray the parts needed hanging on coat hooks. Let dry for 3 hours then prep for overcoat tint.
