Author Topic: 383 build  (Read 6745 times)
Offline Bart
383 build
« on: May 17, 2012 - 10:26:42 AM »
Well the 383 is on the Dyno, turn the key at 5pm today for it 1st run.
383 .060 over
Diamond pistons
508/510 on the cam
Indy Heads
RPM manifold
MSD
780 Holley
Hope to post numbers Friday
Anyone care to guess on HP
Regards
« Last Edit: May 17, 2012 - 11:52:53 AM by Bart »
1970 Cuda 383
2008 Titan
2010 G37s
1996 Advantage Victory 27 502ci
2013 HD Roadking
Offline PlumCraZRT
Re: 383 build
« Reply #1 on: May 17, 2012 - 01:03:02 PM »
383 .060 over
Diamond pistons
508/510 on the cam
Indy Heads
RPM manifold
MSD
780 Holley
Regards
Well, you didn't mention the cam duration or if it's solid or roller, but I'll go with 510 hp.
mmmmm.... Mopar.... *drool*
Offline HP_Cuda
  • Mopar or No Car!
Re: 383 build
« Reply #2 on: May 17, 2012 - 01:47:06 PM »
I'd say it will put out about 440 or there abouts. Keep her running for a good half hour! I can't tell you how many times I've been on a breakin and everything falls apart from ignition to fuel to ...... :cooldancing:
Are we talking at the crank or at the rear wheel?
« Last Edit: May 17, 2012 - 01:49:17 PM by HP_Cuda »
Offline PlumCraZRT
Re: 383 build
« Reply #3 on: May 17, 2012 - 06:46:56 PM »
Good question, I assumed at the crank.
Offline Bart
Re: 383 build
« Reply #4 on: May 18, 2012 - 09:41:45 AM »
Well it made 435hp@5000 rpm on its 1st pull at the crank, with some adjustments we hope to get it over 450hp today.
Regards
« Last Edit: May 18, 2012 - 11:16:02 AM by Bart »
1970 Cuda 383
2008 Titan
2010 G37s
2013 HD Roadking
Offline Road_Runner
Re: 383 build
« Reply #5 on: May 18, 2012 - 11:34:10 AM »
That's pretty close to what we figured my 383 was turning back in the 70's.  You've got better heads than I did at the time, but I was running HIGH compression with 12.5 - 1 TRW's and shaved 906 heads and six pack carbs & intake.  Car was wicked fast, no one could believe it was 'just' a 383.  Nice motor, congrats!
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline Bart
Re: 383 build
« Reply #6 on: May 18, 2012 - 11:41:45 AM »
Thanks, stock bottom end just the cam, heads, intake and MSD, and the 780 holley. compression is a figure about 10.5-1.
Regards
1970 Cuda 383
2008 Titan
2010 G37s
2013 HD Roadking
Offline HP_Cuda
  • Mopar or No Car!
Re: 383 build
« Reply #7 on: May 18, 2012 - 12:40:55 PM »
Damn I'm good!  :woohoo:
Regards
Offline Road_Runner
Re: 383 build
« Reply #8 on: May 18, 2012 - 01:44:39 PM »
I thought the same thing!  I'm not a good guesser myself.
Later, Jim
Offline Bart
Re: 383 build
« Reply #9 on: May 30, 2012 - 02:12:22 PM »
452hp  final numbers
1970 Cuda 383
2008 Titan
2010 G37s
2013 HD Roadking
Re: 383 build
« Reply #10 on: May 30, 2012 - 03:44:32 PM »
Sweet , git it in & have Fun !
Offline Bart
Re: 383 build
« Reply #11 on: May 30, 2012 - 04:06:10 PM »
Neil, Thanks for all your help.....
1970 Cuda 383
2008 Titan
2010 G37s
2013 HD Roadking
Offline GreenFish
Re: 383 build
« Reply #12 on: June 13, 2012 - 12:22:24 PM »
Regards
What Cam did you use?
Offline ragtopdodge
Re: 383 build
« Reply #13 on: June 13, 2012 - 01:15:48 PM »
What size headers?
What Indy heads?  EZs?
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline Bart
Re: 383 build
« Reply #14 on: June 13, 2012 - 03:41:08 PM »
Let me get the cam spec and the head are the 440-ez, also added PRW 1.6 rockers
Duration 284/296, Lift .507/.510, Mopar, Big Block,
Regards
« Last Edit: June 13, 2012 - 04:26:48 PM by Bart »
1970 Cuda 383
2008 Titan
2010 G37s
2013 HD Roadking
