the small block & big block do use the same flywheels , the balancing is different for some applications though .
the pressure plate is the Long style which I have never seen used in a Mopar , but the flywheel matches the PP bolt pattern so they are a set .
There are 2 Mopar flywheels used , a 10.95" with a 130 tooth flywheel & a 11" with a 143 tooth flywheel , both use the same clutch disc .
I would use McLeod for a new clutch if that is what you need , Mancini may carry them
